RKG
Also marine radios are required to monitor Channel 16 at all times. I don't know if commercial radios could do this.
Not true.
True about Channel 16. Hailing should be done on 9 if at all possible, but people get forgetful, or just never bother to read the rules.
Modifying amateur equipment for VHF marine is not a proper way of doing it, but that isn't what the OP was talking about. He is talking about using a commercial VHF transceiver. That is legal if the radio has part 80 acceptance, which many do. This gives you the legal ability to do other things with the radio, including using it for Part 90 use and amateur radio use. While it is certainly not the cheapest way of getting a marine VHF radio, it does certainly allow one radio to fill many roles, which is a cost savings. If the OP was asking for the cheapest way to acquire a VHF marine radio, you would be correct.
Lep, you must be thinking about the identical looking HF transceiver M600 that was companion to the M500 and M500D. Great little radio, fully restorable to LSB and general coverage, but it's weak point was the vco trimmer caps. They should be replaced ASAP if the haven't been. Those too were type accepted in the states outside of the marine bands and could be used for most any other HF application. The state purchased several of them for the old Operation Secure state HF EOC network for some of the smaller EOC's after having too many problems with the SGC-2000's. Much more economical then the TWC-100 that were also in use and easier to use for untrained personel. We modified several as well as the M800 for the early MCI Mail using propritary clover ISA pc boards and for a variant of Pactor II called Pinoak Digital back then for marine in the aftermath of ATT pulling the plug on their HF marine operator. .
Not true, Please quote rule requiring
§ 80.148 Watch on 156.8 MHz (Channel 16).
Each compulsory vessel, while underway, must maintain a watch for radiotelephone distress calls on 156.800 MHz whenever such station is not being used for exchanging communications. For GMDSS ships, 156.525 MHz is the calling frequency for distress, safety, and general communications using digital selective calling and the watch on 156.800 MHz is provided so that ships not fitted with DSC will be able to call GMDSS ships, thus providing a link between GMDSS and non-GMDSS compliant ships. The watch on 156.800 MHz is not required:
(a) Where a ship station is operating only with handheld bridge-to-bridge VHF radio equipment under § 80.143(c) of this part; or
(b) For vessels subject to the Bridge-to-Bridge Act and participating in a Vessel Traffic Service (VTS) system when the watch is maintained on both the bridge-to-bridge frequency and a separately assigned VTS frequency.
[51 FR 31213, Sept. 2, 1986, as amended at 58 FR 16504, Mar. 29, 1993; 68 FR 46962, Aug. 7, 2003; 73 FR 4480, Jan. 25, 2008; 76 FR 67611, Nov. 2, 2011]
Key word there is "compulsory vessel". Not every vessel is required to be equipped with a VHF radio (although they should be).
If a vessel is not required to have a VHF radio, they are not required to maintain a watch on channel 16.
§ 80.1153 Station log and radio watches.
(a) Licensees of voluntary ships are not required to maintain radio station logs.
(b) When a ship radio station of a voluntary ship is being operated, the appropriate general purpose watches must be maintained in accordance with §§ 80.147 and 80.310.
[73 FR 4492, Jan. 25, 2008]
§ 80.310 Watch required by voluntary vessels.
Voluntary vessels not equipped with DSC must maintain a watch on 2182 kHz and on 156.800 MHz (Channel 16) whenever the vessel is underway and the radio is not being used to communicate. Noncommercial vessels, such as recreational boats, may alternatively maintain a watch on 156.450 MHz (Channel 9) in lieu of VHF Channel 16 for call and reply purposes. Voluntary vessels equipped with VHF-DSC equipment must maintain a watch on 2182 kHz and on either 156.525 MHz (Channel 70) or VHF Channel 16 aurally whenever the vessel is underway and the radio is not being used to communicate. Voluntary vessels equipped with MF-HF DSC equipment must have the radio turned on and set to an appropriate DSC distress calling channel or one of the radiotelephone distress channels whenever the vessel is underway and the radio is not being used to communicate. Voluntary vessels equipped with a GMDSS-approved Inmarsat system must have the unit turned on and set to receive calls whenever the vessel is underway and the radio is not being used to communicate.
[76 FR 67612, Nov. 2, 2011]
I was under the impression that boats any vessel equipped with a VHF marine radiotelephone must maintain a watch on channel 16 (156.800 MHz) whenever the radiotelephone is not being used to communicate.
Please see this site for more information.
Here you go.
Per 80.148:
The key here is "mandatory" vessels.
Not to bump this thread, but I thought I'd pitch in a little bit after what I saw today...
I was helping out at a pretty big local dock today and while we were there the CG was towing in this guy who was taking on water. First off, let me say... Those stainless steel boats look TINY in pictures, but in real life... I was amazed at how big this thing was! Pretty wild boat.
I looked around it and looked through the windows inside of it to check out the electronics and what not. Turns out, as one of the first posters in this thread mentioned, XTL5000's were the primary radios. Dual head, one at each station.
Here is some info regarding, among other things, using part 90 radios on the Marine Band....
http://rdept.cgaux.org/documents/Comms/VHFRadioFacilityRequirements.pdf
Rick
I was about to suggest the Icom M-88, but then I realized that it will only has 22 programmable channels reserved for land use (146–174MHz). That might not be enough for many end users.
IC-M88 VHF Marine Transceiver - Features - Icom America
