Using Electricity
glide
Lenoir City,TN
Is it true that phone chargers,scanner chargers ,portable electric drill etc will use electricity even when the devise being charged is disconnected. I know for a fact that a florescent light ballast will draw some current even with the bulbs out.
captclint
Mentor
Mountaintop, PA
YES!!
Thayne
If you want to save about a dime in a month, unplug em all--
gmclam
Fair Oaks, CA
For example, if you leave the wall wart for your scanner plugged into the wall, then take the scanner portable, you might notice the wall wart is warm to the touch ("some" warmth). That's an indication it is drawing power.
Most of these things don't draw a lot of power, we're usually talking milliwatts; but when you consider how many people are drawing these extra milliwatts, it adds up. These days it is not about the cost, it is about the energy usage and contributions to the environment.
Big_Ears
While you're at it. Don't forget to unplug your unused television sets, DVD and VHS decks/recorders, clock radios that are sleeping in any spare bedrooms, dens, utility rooms, attics or basements. The accumulative draw may be up to 100 watts or so.
JnglMassiv
Chicago / 016
Most (all?..) fluorescents I've encountered (CFLs, office tubes, industrial tubes, etc) are switched in such a way that no power reaches them when off. If you flip a lightswitch off, that breaks the circuit and there's no chance for ballast parasitic draw.
n3tg33k
jngl,
Your correct when there is a switch in the mix for lighting there is a switch which cuts all power but anything that needs a DC conversion will draw amperage. All those little black boxes AKA Wall Warts will draw some current because they are taking AC current and converting it to DC current via the use of a transformer. This transformer is what draws the amperage.
N3t
kb2vxa
Point Pleasant Beach, N.J.
Uh, not exactly. An unloaded transformer still draws some current, that which is required to excite the core so naturally it's known as excitation current expressed as Ix.
DC conversion has nothing to do with Ix but when you include the slight DC leakage through the electrolytic filter capacitors and AC capacitive hysteresis currents you have a small but significant draw under no load conditions.
CAPTLPOL1
Thanks to Congress everyone will have to get used to the dim light that a fluorescent puts out. Hope you get used to them. Anyone know if anyone is hoarding incandscent lights yet?
n2mdk
Ames, IA
Huh what, either your buying cheap bad CFs or the wrong Color Temp,mine are anything but dim. 3 13W 5500K bulbs put out more light than 3 60W incands do.
gmclam
Fair Oaks, CA
You're crazy. I've ONLY used CFLs for several years now. Much MORE light per watt than incadescents. Incadescents tend to be a "yellow" light and flourescents are more white, which some say is more harsh. But as far as brightness is concerned, CFLs win hands down.
The issues I see with CFLs are that they don't work with dimmers, and they don't work with cheap photodetectors.
UFEMTFF
http://www.gelighting.com/na/business_lighting/faqs/cfl.htm
See #1 and #3. They answer both of your complaints. :)
Sonar
SoCal
Cable and satellite companies need to make more efficient boxes. If you remove power from them, the boxes lose all settings. Stupid design I say. Then the next time you power up, you get to wait 5-30 minutes for the box to reset.
Thayne
Those boxes have some non-volatile memory, but just like your computer they need to boot up after a power failure. They are designed that way on purpose. They need to be able to adapt to whatever could cause them to go offline.
pogbobo
VA
I AM!!!! i hate CFL with a passion ... i get enough of that while im at work ... i dont need it at home too ... ahhh!!!!
Just_Me
So get halogens.
