I found in Sentinel the setting you can change to alter the time delay after a transmission. Question: Can this be enabled for All or must I go thru each one?
If you are using a Favorites list, you can set delays to whatever you want, on a channel by channel basis- some longer, some not. You can also use negative delay for channels that get too “wordy” with extended conversations after the essential details have already been dealt with.
