cosmo15900
Hi there, I am new here and really hoping someone can help. I am not new to programming and been doing it for a bit now. I have a UV5R, 2 RMV25, 1 Icom F521 and a few kenwood radios. my problem is the same on all of them. I used to be able to program any of them and now when I click "read from radio" the radio goes into programming mode and then i get this communication error. the radio proceeds to reset after i hit ok on the error. I used to have it working and now none of them will program. any clue as to why would be a really big help. THANK YOU very much.
ps. hopefully i got this in the right post. if not i could definitely use some more knowledge. thank you again
KC9HI
If you are using a USB programming cable and Windows, the compatible device driver for the chip in the programing cable was most likely updated to an incompatible device driver. Follow these instructions to verify if you have a compatible device driver installed or not, and to downgrade to a compatible one if you need to.
Miklor.com USB Cables & Drivers
Jim KC9HI
cosmo15900
sorry i forgot to mention that. I tried all the drivers from Miklor with the same results. I am currently trying another idea. I have an older machine that I am putting win xp on and going to see if that works. thank you though
cosmo15900
Tried on another machine with fresh windows install with same results. as soon as i hit read it will not read. tried all 3 cords every driver i can find and im running out of ideas.
cosmo15900
hey everyone seems i found the fix for the relm radios. turns out my usb to serial cable sucks. picked up a cheap pc with serial and relm works. still working on the others yet.
