V1.40 beta Trunking freescan Basic Question
minasha
NYC
I have my G5 updated to 1.40 beta free scan, everything looks ready to go here is my basic question:
When I set up my scan list which will have 3 different systems each with only 2 Talk groups real simple
I assumed i could set it up in zone 1 knob 1 and access it there. Is that right???
Or do i need to go into the menu and select trunking freescan everytime I want to use it?
minasha
NYC
From what I know if you want to scan multiple P25 systems you must
use trunking free scan. You can set it up under PTGL and choose the knob
positions you want to scan.
Can I set my multiple scan list to zone 1 knob 1 for instance, that way I just go to that knob when I turn it on a start listening. Or do i have to go to the menu and select trunking freescan to use?
bkramm
Benton County, IA
There is no way that I know of to set to any knob position.
Only way I do it is to go to trunking freescan and then down to PTGL and select which
combination you have in that list.
minasha
NYC
co nowmbination you have in that list.
Thank you
minasha
NYC
When I go to trunking free skin and ptgl it scans but the backlight stays on constant. Does yours do that
bkramm
Benton County, IA
yes my back light stays on all the time.
guessing it is because it is changing systems, but that is only a guess.
Would be easier on the battery if it would go out after the timeout.
minasha
NYC
It is simple to set a knob position for trunking freescan,
In PPS D6 Pick a zone and knob let's say zone 1 knob 1 if anything is there delete or just use a fresh knob position.
Double click the box and select "trunking freescan" in receiving mode.
That's it! Now whatever you have when you manually select trunking freescan from the pager's menu will be duplicated in that zone and knob.
W0RS
Nixa, MO
I plan to get a G5 shortly. I do want the scan feature but, it appears to be in beta testing. Has there been any comments as to when it will be released in a usable form?
radio3353
No.
kruser
Well Known Member
W St Louis Cnty, MO
I had the Freescan Beta but went back to the standard firmware now at ver 1.3.
This version still has the talkgroup hold and talkgroup block feature which is really all I needed.
I tried the freescan feature and let my G5 scan between an upper and lower limit that I set but I can't say it was anything I really needed.
All my other scanner do that function much easier and also work well enough regardless if a site suffers from LSM. The results were always good enough for finding new things instead of getting into the G5's menu with PPS and programming freescan limits.
I suppose for some, the freescan feature would be very handy but if you have other scanners that can decode P25 digital voice, I think you will find them easier to use than the freescan feature.
In time, Unication could add to the Freescan feature and if so, I'll look at that again.
Freescan may also be nice if you travel into areas your G series is not programmed for any systems.
WX4JCW
Stow, Ohio
ok, I missed the beta as I got my radio the day after it closed, but let's say I'm monitoring a state system and have 3 different talkgroups, but each talkgroup is fixed to a particular site so TG A is on Site A TG B is on Site B TG C Is on Site C, will the free scan make it possible to monitor all 3?
the reason i ask this is at Home we have 1 system but 2 different simulcasts one for Orange County and one for Orlando, some talkgroups are on both but some are not
Webodisk
Silent key.
Virginia Beach,VA
Yes, it does a pretty good with multiple systems as long as you don't get carried away LOL
tkowalik
Banned
I scan 6 sites across 2 systems with a delay of 3 seconds and while you will miss traffic, I find it isn’t much. I set mine up as each knob position has one site and only the control channel (no alts) and then scan.
