Vehicle antenna question
FrankM
Sioux Falls, SD
What is the best antenna for a vehicle for use with the P25 systems here in South Dakota ? Thank you !
Bob1955
Eastchester, NY
Frank-For a magnetic mount antenna, a Hustler MRM-BNC which includes 12' of cable, a strong magnet and good 25-1,300 Mhz range.
I have one so any questions, reach out.
Stay safe.
prcguy
What frequency range do you need? The Hustler antenna mentioned is simply a VHF whip with a loading coil/trap for the top whip tuned to a single frequency in the 30-50MHz VHF lo band. It has no specific elements for UHF or 700/800 and would rely on the VHF whip being a 3/4 wave on VHF which works but is not ideal. If you need UHF or 700/800 there are much better choicesm (and much smaller) and since you mentioned P25 you probably don't need VHF lo band which will make any antenna much longer.
Bob1955
Eastchester, NY
prcguy- The antenna for me, did a fantastic job on VHF LO/VHF Hi/UHF, and also 700-800 Mhz trunking P.25 and the price-point isn't bad either.
You are getting too technical for someone that "probably" doesn't know about 3/4 wave and or trimming a antenna.
prcguy
"Did fantastic for you", compared to what? How do you know it doesn't work that well compared to something else?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Looks like the state operates a VHF P25 trunk system. Based on the frequencies in the data base, a VHF half wave would be an excellent choice if you only want to listen to the state P25 system. If you want something lower profile, then a basic VHF 1/4 wave will also work well.
If you want to monitor some of the UHF mobile extender frequencies, then a multiband antenna will serve you well. Even a 1/4 VHF will work, as it is also resonant on UHF.
