How do you remove the case from a Bearcat Electra BC101?
I see two plastic caps on the side of the case, should I remove them to access hidden screws?
Something loose inside and I need to remove case to see if it's a loose part (nut/screw/etc).
Also how do I get service info on this scanner? Did Bearcat make a service manual or some aligment instructions?
Thanks.
Thanks.
