What dongle did you buy? Would you mind sharing the url where you purchased it at?
Robert
Robert
Robert
I am using the setup as described in the QST article with NooElec R820T SDr and DVB-T and the homemade collinear antenna. Software is ADSB#, and VRS 2.0.1. Frame rates are 30+ (near O'Hare Airport) and data viewed by telnet.exe looks normal but I get zero aircraft tracked in VRS
Posted a screen shot of the programs running on my desktop. The receive end looks good but aircraft do not show up when I connect to 127.0.0.1 I have also download the SBS Resources for the database and have set the paths correctly.
One problem I have noted is that my setting in VRS do not seem to "stick" and I have to re-input them each time I start the program. Mode is set to Beast and Port is 48706.
Any ideas on what I could be doing wrong?
Bill
Port 48706 is that just a typo...are both ADSB# and VRS set to 48706. Mine are set for 47806. might be why your screen shot is not showing connected.
When I enter a receiver and port number, and test it, it says a connection can be made, but when I exit the setup, it doesnt save it, and when I try to pull up the map, I get a map of England. How do you get this program to save the information?
It also keeps telling me it cant find some sqb file when it loads, but there is no sqb file in the zip. The instructions are all over, but the screen shots have all these settings that the program doesnt. Apparently they changed it since the screen shots were made.
Anyone have any current info, like step by step for an idiot, to get this program running? According to the ADSB# program, there are 9 aircraft in range right now. Just cant get this virtual Radar program to work.
Figured out I had to change it on the map, I guess, after I ran it. Now showing two aircraft flying with full stats, and several flying that show no stats...Guess its working. Just using an ST2 antenna right now, havent built the 1090Mhz one yet.
