w7cma
I am a feed provider and wanted to control the BCD996P2 and monitor the audio over the Internet. The problem was that RadioFeed ( using channel tags) and ProScan both wanted to use the one com port I have available. So I could not do both at the same time. The solution was very simple. Virtual Serial Port Driver PRO is a vertual com port driver that allows you to share one com port with more than one device or program. It is very simple to use but filled with features. I can now connect to ProScan over IP and controll the scanner plus monitor the audio using ProScan client and still have channel tags. When I add a second scanner all I have to do is generate more virtual com ports and connect the scanner. I am writing this in case I can help someone with this problem. If you find this helpful post a comment.
Disclaimer: I am not employed nor have any connections with Eltima Software, the makers of Virtual Serial Port Driver.
