Virtual Serial Port Driver PRO
w7cma
Missoula, Montana
I am a feed provider and wanted to control the BCD996P2 and monitor the audio over the Internet. The problem was that RadioFeed ( using channel tags) and ProScan both wanted to use the one com port I have available. So I could not do both at the same time. The solution was very simple. Virtual Serial Port Driver PRO is a vertual com port driver that allows you to share one com port with more than one device or program. It is very simple to use but filled with features. I can now connect to ProScan over IP and controll the scanner plus monitor the audio using ProScan client and still have channel tags. When I add a second scanner all I have to do is generate more virtual com ports and connect the scanner. I am writing this in case I can help someone with this problem. If you find this helpful post a comment.
Disclaimer: I am not employed nor have any connections with Eltima Software, the makers of Virtual Serial Port Driver.
w7cma
Missoula, Montana
Here is the way it looks when it is all done. And a link to the software. I hope this will make it more clear as to how it all works.
Virtual Serial Port Driver - create and emulate virtual COM port
Here is RadioFeed on Vertual port #1
Here you can see ProScan running on vertual port #2
Here you can see the native serial port com6 and the the 2 Eltima Virtual Ports com1 and com2 on Device Manager
Here you can see native Com port 6 being split into com1 and com2.
eaf1956
Evansville, IN
Of course this becomes irrelevant on the SDS 200 line. But, could be useful for older models using serial ports.
Sent from my SM-N960U using Tapatalk
