Visar programming trouble/rib comm. unsuccesful
agm13
Hello everybody!
I have a big problem which have been completely described at topic.
So, there are couple Visars, model H05KDD9AA4DN.
I have two (tried both) programming cables with RIB.
I also have program for HT1000/JT/Visar, its version is 3.03.
Everything is officially from Motorola!
I run it with old computer on windows 98 in DOS mode. Everything i can get:
"RIB PORT COMMUNICATION UNSUCCESSFUL"
Please, provide any help, if you can.
WPXS472
Heflin, AL
I don't think a DOS window in any flavor of Windows will work. I am no expert on this matter, it is just that I have never gotten that particular software to work under Windows. I know this sounds like a broken record, but, get DOS. A DOS window running within Windows isn't the same as DOS. If I remember correctly, this particular software isn't sensitive to processor speed, so you can run it on a fairly modern PC.
cmjonesinc
If I remember correctly on win 98 there's a restart option that boots you to straight dos correct? So I assume when you say you're using dos you mean actual dos and not a dos window inside of 98. If that's correct, have you checked your com port assignment in the software (F9)?
If all of that is right I'd make sure the contacts on your radio are clean. Lightly cleaning them with a pencil eraser works well. The only other thing I can think of is are you sure it's the right cable? There's a few other cables to look the same but are pinned differently.
radioman2001
New York North Carolina and all points in between
The larger issue is that the clock is too fast, you need a 486 SX-25 or slower. The same problems occur when programming analog Sabers. and you can actually corrupt the code plug. The DOS mode in Win 98 will work, but again it's the clock speed issue. There used to be a program called SloMo that helped, but I have never personally used it.
agm13
Yeah, i am using "real" dos. At first i am tried on XP, windows 7 compatibility modes, windows 98, and, finally, in dos mode of windows 98.
I also check contacts of the radio even before all that. And i know for sure that the cable is OK, at least it was OK couple years ago by the customer words.
Wow, for real? Well, i will try something -- somewhere i have very old laptop and it have real DOS on a board. If that will not work i am afraid i would need to throw out 30 working stations...
cmdrwill
So Cali
The later version software does not have a timing problem,
Software only runs in real DOS, not "in dos mode of windows 98", a "dos window", or DOS "BOX".
Remember the software was written way back before Windows 95.
agm13 if you need help, just PM me.
agm13
Solved
Well, somehow i was able to find very old laptop, with 386 sx
But, it has win98.
BUT, it worked!
Wow, so, for anyone who had such a problem: get very old pc
