I am doing DMR scanning with confirmed freq's - small number of freq's. Good antenna, etc.. I do get audio but it short and choppy to garbled. I see Cach errors on the output. Suggestions? My two bat files, FMP24.cfg file contents and output documentation are below:
FMP24 -i2 -o20003 -P0.0 -s1
DSDPlus -e -i20003 -fr -o4 -O NUL
2.4 ; sampling rate (1.0, 2.0 or 2.4)
1024 ; spectrum window width
32 ; FFT size (8k, 16k, 32k)
20 ; spectrum update rate in Hz - Original was 10
5000 6250 7500 12500 15000 20000 25000 ; step size table; units = Hz;negate default
. ; DSD+ path
.\FMP-FreqList.csv ; primary frequency list CSV path\filename
.\FMP-FreqList2.csv ; auxiliary frequency list CSV path\filename
miles ; search units (miles or kilometers)
99.9 ; search distance
44.630978 -86.072480 ; search origin
DMR CACH ERR slot1 BS DATA ERR2 DCC=5 TLC ERR12 ECC FAIL
CACH Sig ERR2
+DMR CACH ERR slot2 BS DATA ERR1 DCC=5 Idle ERR11
+DMR slot1 BS DATA ERR3 DCC=1 Rate 3/4 Data FEC FAIL
+DMR slot2 BS DATA ERR2 DCC=5 Idle ERR24
+DMR slot1 BS DATA ERR1 DCC=5 TLC ERR14 ECC FAIL
. ; DSD+ path
CACH Sig ERR2
