VP8000 Cases
otobmark
NC
When will we get some VP8000 cases? I’m tired of ill fitting generic cases. Among other variations, I’d like a case with its own clip so I can dispense with radio mounted clip.
tlemke940
Lyons, OR
are you talking about a case like what Boston leather has that goes on a radio strap or are you talking more like a turtle back case?
tlemke940
Lyons, OR
it also looks like Radiotech has one that can go on a belt or on a strap.
otobmark
NC
Clipped to belt and also sitting on desk (want protection if knocked off). For field I’m just now trying chest pack. Basically the radio goes on and off my body often, thrown into or clipped onto my pack.
tlemke940
Lyons, OR
ya for that it is probably going to be a hard find but i do know with the Boston leather one the factory belt clip is somewhat usable depending on what battery you have on it
AF1UD
I'm a big fan of the Boston Leather with the D-Rings, best part it allows me to leave the belt clip on the radio!
otobmark
NC
The firefighters all use Boston Leather rigs. I have never considered a strap rig. Always thought it would be cumbersome.
rescueman433
I’m also looking for something. What use case / environment do you operate in. Mine sees a mix of fire/ems/law, ops and admin so the leather strap doesn’t always work.
otobmark
NC
Emergency Management esf2 stuff. Not usually crawling around in the dirt or wearing turnout gear. Maybe a kafaru ruck sack with
matching gun belt 🙄
wsp44
zero9 holsters makes a nice kydex holster, with a couple different mounting options, They don't have the VP8000 listed, but I can confirm that it works with the VP6000 option, I believe they told me they were waiting to get a VP8000 to create a mold.
Boston leathers option is better than the BEE IMO, Like a couple folks mentioned, they had a couple slots cut on the rear so you can keep the belt clip.
If you would like tomorrow I can get a couple photos of the BEE case, I believe we have a couple in stock. The Boston leather cases are out with our DEMO VP's so we could just keep the belt clip on.
BigLebowski
Piedmont NC
+1 for Zero-9 and they do list the VP6000/8000.
otobmark
NC
Probably get one of these. While I had belt use in mind I could add some molle clips for pack use. Does the radio lift out easily? I’m often setting radio on desk and don’t want to take my pants off to do it. Need occasional access to front panel as well. Also what is tek loc? Is it a rotate to remove clip?
BigLebowski
Piedmont NC
I don’t have a VP case so I don’t know the level of retention but you will have to remove the radio from the case to use the keypad.
Tek-Lok is a non-rotating belt snap designed for duty belts but will work with others. You can put the case on your belt without taking it off though.
otobmark
NC
Ordered for VP and APX radios. Lots of extra hardware to play with. Hopefully able to quick swap from chest rig to battle belt. My packs have large generic pouches (PRC size) which is fine. Final challenge is to overcome mic cord tangle🙁
wsp44
if you turned the case upside down with the radio in it without the retention cord around the channel selector I believe the radio would fall out with a couple good shakes, the retention isn't tight. When I originally spoke with Z9 months ago they said they were waiting to get a VP8000 to do a mold, but they said the dimensions of the VP8K was close to the VP6K so the VP6K should work.
otobmark
NC
Supposedly mine comes in tomorrow before noon re FedEx tracking so I guess I'll find out. The VP8000 is bigger than VP6000 for the top third of the radio which is mostly out of the kydex. Wonder if Gucci has one in the works? I'm never satisfied when fitting equipment to my person. I bought every mounting option to play with and will report what happens.
SimplyTech
Any updates? I am in this same boat lol.
