VP8000 Cases
wsp44
I just went back and verified, but with the VP8000 and the KNB-L3 the radio won't come out of the holster, its retention is pretty good without the bungee cord around the channel selector, so I stand corrected to my prior statement.
otobmark
NC
IMG_2188.jpgIMG_2183.jpgIMG_2185 4.jpgFirst photo compares the two mounts--top is quick disconnect and the lower with belt clip. The quick disconnect when all assembled and using molle clips to attach to one of my battle belts puts the holster about 1 5/8 inches from my body (back of belt). The belt clip setup puts the holster about 5/8 inch from my body (back of clip).
Second photo is of two battle belts with left one using belt clip and right one molle plus quick disconnect mount. I will probably use the quick disconnect setup on my right side (can swap in pistol) and use belt clip to add radios anywhere else on the belt.
I tried the molle clips plus quick disconnect (blade tech) on one of my chest packs and the radio sagged away from my chest enough to get in the way. I can't really use molle clips alone on my chest pack because the radios would be vertical (antenna up nose). With quick disconnect system you can change the angle to point antennas off to the side but the stand off distance was too great. If I was wearing something stiff like a plate carrier (if you see me wearing a plate carrier then none of us should be there!) then it would probably work but I would much prefer radios on side of plate carrier cumber bun area as is usual case.
The zero9 kydex holster design (channels for mounting screws moulded in) will always prevent mounting radio tight to the body the way a fabric/leather case with belt loop or built in clip can. If you are accustomed to standoff from carrying a duty weapon and other gear then you will be at home with zero9. My battle belts keep everything solid to my body and nothing bounces if I run (If you see me running then you should run too....) or move in and out of vehicles. As poster above mentioned about friction retention, I don't strap in radio when working command post or other highly civilized area so I can quickly snatch out radio and sit it on desk etc. In rougher conditions I tie down radios and when stationary/seated for long periods I just remove my battle belt (takes 2 seconds to remove, maybe 6 to attach because of aligning battle belt to inner belt going through my belt loops) and hang is over chair or something.
tweiss3
Is it time for Coffee?
Ohio
@otobmark You have had this for months, any additional notes or change in your opinion? Is yours with the L3 or L11x battery?
otobmark
NC
During Helene I was at Western command so not stomping around down range or riding choppers. I carried an APX & VP which was fine until sitting in any chairs with arms—standoff made me too wide and I barely have enough a$$ to keep me upright in a chair. Outside running cables and standing up antennas the rig was fine and secure. In a situation where you are running a loaded battle belt (weapon, mags, knife, ifak etc.) the Z9 integrates in well. The shock cord keepers would actually cut through the VP rubber armored knobs. Made me rethink rubber clad knobs period.
In general I don’t like the standoff—closer to body would be better for me. Bright spot was not being poked with antenna or deforming it. If Z9 didn’t have channels for screws it would have met my standoff requirement.
With 3,400mah battery it worked fine and enough retention for anything short of combat without using cord—exception might be accidentally pulling it out by tangled RSM. So removing and replacing the radio is quite good. With the slim 2000mah it just rattles around and needs cord. I don’t have the newer 11 battery. I actually often use the 2000’s because I can buy oem for super cheap ($9 each). Big batteries are $60-150 oem. I’ll go for 11’s once they go below $100 or so.
What I want for office is a case that stays on radio and has its own supper duty easy open spring clip and protects radio from scratches and drops(padded on bottom corners).
For now I will keep using Z9
BigLebowski
Piedmont NC
Auxcomm must be getting dangerous if we are running plate carriers and battle belts. 🙄
