VRS-EP tranceiver Issues
thecircusbear
Good evening, thank you to all in advance for your assistance in this matter.
I had ordered a VRS-EP (P2017A and P2017B) UHF repeater from someone on ebay, opened it up and discovered no transceiver on the YLE4009B board. So, I get my money back, order another and sure enough....no transceiver AGAIN. I have a number of questions as im trying to purchase parts needed to get these units working again:
First, does ANYONE have a picture of fully assembled VRS-EP internals WITH the transceiver? Please post them if you do, I cant find any.
Second, The Rnet-SLM 450 data radio, I can find VERY little info and even less for sale online. can anyone provide a part number for the correct cable needed to interface the rnet with the YLE board within the VRS? I believe the rnet has the db9 female port in this configuration, but cant seem to find any db9 to 16pin cables (the 16 pin connector being what i believe it plugs to, hence needing the aforementioned picture) It also could be a DB15 rnet...again, very little info i could find
Third: If i were able to purchase another uhf data radio, say from midland....with the above mentioned cable, will it allow the system to work? My main question being are the pinouts for the Rnet and other data radios sporting the DB9 the same? (doubtful, but im not the expert). Or are there any to your knowledge that share the Rnet pinouts?
Fourth : Are there any other options for integrating a uhf radio to this board? Ive tried researching the EXPO radio, the P50 aswell with little luck. Im not very adept at soldering so a plug and play setup is needed. Thank you.
