VSTARS Programming BC396XLT Question
Jimru
Henrico County, VA
Hi All,
I recently moved from Massachusetts to Henrico County, VA and I have a question about programming my Uniden BC396XLT for VSTARS.
According to the RRDB, it's a P25 system, and with numerous talk groups, I would assume that it is a trunking system, but I'm confused about how to initially program this into the scanner. The Glen Allen (Henrico) tower uses the following freqs:
152.15750
152.20250
152.60750
152.75750
My scanner gives me several choices for programming this system:
Conventional
Motorola
EDACS
LTR
Which one is appropriate for this system? I'm going to start on MOT, as I can't believe it's a conventional P25 system.
Any help appreciated!
I have successfully programmed in the Henrico/Richmond/Chesterfield TRS with good results so far.
Thanks,
Jim
RagnarD
In a valley that only a few know where it is
Not familiar with the 396XT but using my 396T STARS is programmed as a Motorola APCO 25 system using Butel's ARC 396Pro.
Looking at FreeScan it imports it from RR as a Moto Type 2/P25 system.
STARS does have some odd trunk tables so it may be worthwhile to grab FreeScan to program it.
See the screenshot in the attachment.
Jimru
Henrico County, VA
Thanks, I will check this out!
So far, I have no joy on the system the way I programmed it (as a MOT P25). I'm going to see if I can even receive ANY signal at all, as I'm living in a basement apartment (with plans to move at the end of the lease), but I do get the Hen/Rich/Chest TRS loud and clear.
Jimru
Henrico County, VA
Actually, an update:
I got up off my lazy bum and walked to the window and can receive the system!
I just need to set up an antenna next to the window, rather than sitting with the HT on the desk.
Thanks again for the response!
