VX-3200 Programming Issue - "Open Err" message
isocaman
Greetings:
I am trying to program a VX-3200 using the CE52 (v4.85) software, Windows XP laptop and a USB programming cable. Per my understanding of the programming instructions, I first attempt to download the current programming from the radio with the intent of saving that file, making any changes I require, and then uploading the updated file to the radio. Each time I select the "Read from Radio" command, I receive the following error message - "Open Err". The LCD on the radio does display "PGM" so I believe that it is recognizing the cable/computer.
Any assistance in resolving this issue would be greatly appreciated.
Chris
VSTech
Borden, IN
VX-3200 are legacy radios, you should use the VPL-1 with the Comm1 port connection.
FIF-8 is used only for updating the firmware
I do not recommend using a FIF-10A or FIF-12
VX-3200 also make a LTR version and requires CE47
