VX-829 programing question
KB7IWO
I am new to radio programing. I am trying to program a used vertex Vx-829 radio with with CE76 and a CT108 cable. I keep getting a "model mismatched" error. The display on on the radio says "PC Program" Any suggestions from the experts on this forum? Thanks
radiotweester
Oregon
if you have a standard VX-829 (analog only) and not a VX-P829 (P25) you need to use CE-59. Ver 5.04 was the last I'm aware of.
willdanl
Dripping Springs, TX
Are you able to read the radio (upload)? Do you have the correct product type selected and an appropriate freq band?
carlos7801
Lawrence MA
CE59 = VX820/920 series
CE76 = vxP820/920 Series
Verify you have the proper cables, drivers, and your com port can see the device with no issue
KB7IWO
Hi. I was just informed that this particular radio needs CE-106 Talon software. Thank you for the help.
radiotweester
Oregon
Ah the infamous P829 Talon radios strike again...
As they were former Federal radios a lot of the regular features have been stripped. They'll do P"25 fine.
KE4AXW
I just got one of these. These are pretty cool. Mine needed the talon edition as well but I haven't seen any feature missing. Only issue I have is when using field program. Even though I have the p25 options enabled in the field program section of the CPS, when I go into a digital channel it does not show them. Anyone have success editing p25 settings on a channel ?
radiotweester
Oregon
I was thinking MDC, 2tone and some other things were missing. Nothing Ham usually uses.
Don't take this as gospel as I never did FPP with these (only Motorolas).
I think you need to set up channels with P25 freqs program and then edit those?
Talon users????
Under Common there should be a tab like this.
This screen shot is from the from the CE76 and not the Talon version.
73s
KE4AXW
ok, i figure it out from another forum. you have to press the orange key to get to the digital parts/continued menu while you are in FPP
