VX-924 Programming
KyFireFreak
Northern Kentucky
I need some assistance with some advanced settings on a VX-924. These are VHF units with UHF Rx. and the VME-200 boards for MDC installed.
1) How do you select which channels are on the scan list. I have have double checked that all channels and groups set as user defined on the channel itself and within the scanning tab.
2) How do you set up group scan in order to scan across multiple groups. Right now I can only scan within the 16 channels of the set group im currently in.
3) I have set in the MDC1200 tab for the PTT side tone but the radio still will not sound it upon keying up, what am I missing here?
I had a demo unit for a lil bit and it did all of these options so I know all of the above is possible, just cannot figure it out. Thanks in advance for the help.
radio259
Pittsburgh PA
Is it possible to send me the file?? I can fix it. Rahter involved to write it out. In the CE 73 software, you need to select PTT ID as "PTT down or beginning. CE 73 escape me but there is an otion for sneding ID at the front. mkae sure your lead in time is around 400ms. Some systems need that much time for the system to get in sync and the ID to pass and be decoded.
Really great radio. Easy to use and good size.
