VX P929
Bill1957
New Jersey
Hi,
Anyone have a P25 uhf code plug for conventional P25? Programmed Mortorola and Kenwood and Midland in the past. Can't figure this one out. Help files are of little use.
Thanks,
Bill
Ant9270
The Green Weenie
Hi,
Thanks,
Bill
What exactly do you need help with? I’ve spent hours on that software. Are you using CE-76, or CE-106 TALON?
Ant9270
The Green Weenie
Click on the option box you’re trying to work on, click the space bar. Type in your RX/TX, then your NAC. Ensure you have MODE on RX/TX set to “D” and also set the ID Display box in the upper left corner to HEX.
lkas
Cheektowaga NY
have u ever seen a issue programming the PF keys?? I have a vx-p824 with the ce-76 software. When I program the "A" key it works on the "D"button. The "B C D" button will not program. Been playing with this issue for 2 weeks. no matter what I put in them nothing works. If you physically press the B C or D button the backlight illuminates and that's it.
Ant9270
The Green Weenie
Are you utilizing an option board?
lkas
Cheektowaga NY
no, this radio does not even allow for a option board. In the location a option board would be installed there is a board installed for p25 capabilities from vertex already.
Ant9270
The Green Weenie
Actually, you can use an option board, but you would lose the P25 capability. The only option board I’ve tested that does not work within the “P” series is the VME/VMDE series. Have you tried forcing a new codeplug in? Sometimes the data becomes corrupted, and the radio starts doing odd things.
lkas
Cheektowaga NY
I need the option board that came with the radio as P25 capability is why I purchased this radio. I too purchased a VMDE-200 to only find out it does not work as well. I have tried a new codeplug with negative results. I opened a new code plug, programmed in 2 freq and functions on key A + b to do channel up and down. I had no luck.
Ant9270
The Green Weenie
Have you opened it up and checked the flex cables?
lkas
Cheektowaga NY
no i have never opened up one of these radios.....if it is not too tricky i dont mind doing it......
lkas
Cheektowaga NY
so I opened up the radio. Pretty simple process. The flex cables (2) were both solid. I disconnected them and reconnected them just to be sure. Still no difference. I did get a updated firmware from Motorola but it requires the FIF-12 cable which goes for about $150 online. I am not dropping that kind of cash on a cable especially when I don't even know that will fix the problem.
Ant9270
The Green Weenie
You can send your codeplug to me if you want, and I’ll take a look.
Bill1957
New Jersey
Thanks for the reply-It was of great help!!!
Bill
