VX5500 w/ MDC1200 Option board
eportel6607
South County, Rhode Island
I just received the VME-100 board and FIM7a board to allow my Vertex VX5500 radios to have MDC1200 encode. I have enabled it in the software but I can't seem to find where to make the adjustments to the signalling. I'm looking for MDC ANI code ID number, the Post/Pre on PTT selection and the delay after PTT.
Anybody know where the adjustments are for this options board in the Vertex programming software?
radio259
Pittsburgh PA
You program the VME100 board thru CE73 software.
With radio off, press and hold the power button and I believe PF3. If not three, may be PF4. then read the board and set your parameters. (Could be PF2) Been a while since I set up 475 of them for local transit authority.
eportel6607
thank you radio259 for your efforts. If you re-read my post, I have the software running just fine. I simply can't find the window/screen within the software to adjust the setting on the MDC1200 ANI. I thought that it would be similar to the DTMF ANI screens as far as options but it's all grayed out now that the VME-100 and FIM7 boards have been installed. The default MDC PTT ID is #1234 at 100ms... I need to be able to change the ID number and the duration of the ID.
