VXD-R70 problem
FLMedia
Oxnard, CA
So I found a VXD-R70-G7-40 recently.
I fired it up and seems like no issues, I can read and even write to the unit.
But when I key up on my HT the repeater just power cycles and reboots. I opened it up and cleaned out all the dust and what not.
But I do not know where to go from here. Anyone have any ideas???
Thank you!!!!
FLMedia
Oxnard, CA
No duplexer. Using 2 separate antennas antennas. I do have a tuned duplexer I can try on it though
DieterBohlen
Germany
You should test the power supply with a dummy load!
A 50 W halogen bulb should work for it.
If the voltage breaks down,change or repair it.
FLMedia
Oxnard, CA
So I was able to get 1 of the repeaters going with a power supply out of another 1. So now I know I will need to find 2 other power supplies. Also I am not able to read the other 2 repeaters so I assume the Connector board might be bad since both of them are pretty rusty..
Thank you for the help everyone!
FLMedia
Oxnard, CA
Alright so after having these sit in the house and messing around with them I took 1 up to our tower to see what it could do. Got it running and everything worked fine while I was at the tower. When I got half way down the hill the repeater wasn't RXing anything. I went back up the next day and the repeater would RX while I was close to it. Brought it home and connect to CPS, now the repeater will power up and I can still read/write in the CPS but the repeater will not RX and no other lights on the front panel are on except for the Power light.
Can someone please help me with this issue? Or is this thing now a paper weight?
Thank you!
