VXR-7000 Community Repeater Operation
BlueDevil
WA
Does anyone have any experience with the Community Repeater Operation feature on the Vertex VXR-7000 repeater?
How does this feature work?
Thanks for the help!!
PACNWDude
VXR-7000 Community Repeater option.
This option allows you to have different users on the same frequency, but using different PL tones on the repeater. An example, a local school can use it and only hear their traffic and then the local amateur radio club can use it and only hear their traffic. It is a little tricky to set this up though.
Are you able to get into the programming screens for your repeater? Once you select "Y" for the "Community Repeater" option, it should prompt you for more settings for individual tones and users.
kg4ciu
the last poster has a good idea of how it works but is very wrong on the users end.
the vxr7000 will allow you to program up 16 additional pl/dcs codes to operate the repeater.thus creating talk groups. Which means the repeater can be programmed on the licensed frequency, ie 465.500
,different groups can utilize the same repeater with out having to be disturbed by the traffic of the other user, by utilizing different pl /dcs cod groupings. However only 1 user can operate at a time it would be advantageous for the subscriber uints to enable busy channel lock out feature of the subscriber radios to prevent transmitting on top of other user already using the system
