Wake Co/Central NC Smartzone Update!
KE4ZNR
Radio Geek
August 30th, 2004: ATTN: Website link updated below! Please note URL change! Let me know if you have any questions! Thanks!
Hello all....
Just a quick note to let you know I have updated my Central NC/Wake County 800Mhz Smartzone ID list...the current copy can be found in xls (excel) format at the following URL:
http://nctrafficman.net/Wake800/Waketrunked.htm
Let me know if you have any additions or corrections!
Thanks & Happy Monitoring!
Marshall Sherard, KE4ZNR
http://trunked.nctrafficman.net
[/url][/b]
thumbtrap
At my computer, duh!
Does anyone know about control frequencies for durham? I found the whole list on Marshall's spreadsheet, but the control frequencies weren't marked. Once I figured out how to put the BCT8 in CConly mode - I think it scans a little quicker.
thumbtrap
860.9625 is a control frequency as well. How does this work - how often do they change, and if a channel is not the control frequency at the moment - can it be used for voice? I created another trunked bank, and have been adding controls to it and deleting them, as well as frequencies I've heard voice transmissions on from the other bank. I'm not positive that that's a valid assumption (that just because a channel carries voice today that it might not be carrying control tomorrow.)
KE4ZNR
Radio Geek
I think we may be getting 2 different trunked systems confused :D
My excel spreadsheet above is for the Wake County Smartzone only...it has no Durham 800Mhz info at all...the Durham 800Mhz Info is available via my website at http://trunked.nctrafficman.net ...and I believe Durham just switches between 2 Control Channels so if ya get those 2 then you should be good to go :D
Hope this helps!
thumbtrap
Not confused, we're just hijacking your thread. (The durham system is listed on your page.) I believe when it came up before, it was mentioned here that Durham uses (or used at the time) four control channels which rotate. But no one had the control frequencies. I found a frequency on the list of durham freqs that does not appear to be a control channel, but seems to carry only digital (broadband) noise in short bursts. It doesn't sound like 3600 or 9600 baud stuff - much more broadband than that. It didn't seem to be a control channel, nor did it hop around like a talk group.
INDY72
Indianapolis, IN
If it is a chan for non CC digital data then there is a MDS in use.. (Mobile Data System) All part of the abitlity of seamless connectivity provided by Motorola... you get paging, MOSCAD, MDT, as well as voice.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Marshall,I get an error message as the pdf attempts to open. The two zips worked fine, thanks for the update.
KE4ZNR
Radio Geek
Just tried it and I was able to view the pdf just fine...if you email me with your email addy to MSherard@gmail.com I will email it to ya...
thumbtrap
It moved again, as far as I can tell the following are control frequencies for durham:
860.9625, 858.9625, 857.9625, and 854.9625
They were all in the big list, but now you can do CC only trunking. How do we get this logged in the RR database?
