Walworth county
jj53191
Williams Bay, WI
I'm looking to talk to someone in the Walworth county Wisconsin area who is
successfully monitoring the Walworth county P25 system using a TRX-2 scanner..
I have tried every suggestion with no luck.
I would be interested in talking to you about your scanner settings and set up.
Thanks ahead of time.
wx9kvh
Radio Nerd!
Outagamie County, Wisconsin
You won't be able to hear the Law channels, just the Fire/EMS stuff. The TRX-2 scanner is inherently bad with simulcasted systems.
kpc430
I’m looking to get my WS1065 back up for Walworth county as well
OpSec
All your WACN are belong to us
Monitoring the database
You need a scanner that can handle all forms of P25 simulcast. Can the Whistlers do that?
whop94
Middleton, WI
Unfortunately you are not going to be able to monitor a simulcast system reliably with any scanner that's not a Uniden SDS-100/200 or a Unication G4 or G5 pager. There may be pockets of the county where you are close enough to one tower that you might be able to decode ~75% or so but even that is spotty. You could also try a highly directional yagi antenna aimed toward your nearest tower. I tried for years to get my TRX-1 to decode DaneCom and concluded there just isn't a practical way to do so, your standard scanner simply can't handle it.
jj53191
Williams Bay, WI
I'm not hearing transmissions on any of the Walworth county talk groups assigned to Public works .
It's been a couple of weeks since I noticed not hearing any.
Wondering if I'm missing something.
On my SDS100, I've cleared all user data, deleted and reinstalled the WalCo P25 database and still no luck.
Has anyone heard of talk group changes or going encrypted?
John
rdmcvicar
Middleton, (Dane County) WI
Taking a quick look at today:
Fontana 65302 seems pretty active.
Plus county highway.
(This may sound desperate) and a brief open mic on Williams Bay?
jj53191
Williams Bay, WI
Thanks!
No problem with county highway, county EMS paging, dispatch or any fire locals.
Just no public works.
I ran Proscan for awhile.
Yes I did see a few from Fontana DPW but no others.
Do me a favor if you would.
If you see anything other than Fontana, let me know.
Thanks again for the reply.
tvengr
Well Known Member
Baltimore County, MD
The Walworth County trunked system is all P25 Phase 2. The WS1065 is capable of P25 Phase 1 only. You will
not be able to monitor the trunked system even if simulcast distortion is not a problem at your location.
tvengr
Well Known Member
Thanks!
Please attach your TRX-2 programming file so we can take a look at it. Also, please attach your ProScan favorites list file or export and attach your Sentinel HPE favorites list file. You will need to zip the exported HPE file to be able to attach it. Is the Public Works service type enabled in the profile?
jj53191
Williams Bay, WI
Was hoping this was the fix.
Yes, it is checked in the profile.
I Unchecked everything in the profile and then rechecked everything.
Wrote everything back to the scanner.
Hope this was the glitch.
Thanks!
I’ll keep you posted.
