washington base problems
australia
I got this fairly nice looking Washington uniden base station last Month...
Fired it up and excellant --til I started around the channels yesterday , normally just sit on 35 excellant.
Well, I logged the faulty channels and would you believe that 20 of the 40 channels are dead.. My brother listened at his house as we went through the 40 channels..
Now , someone much smarter than I out there may be able to help -could it be the rotary switch needs attention ,or will it be a big chip hard soldered to the board??? yuk..
I am confident of fine soldering , with care I would be able to do this job ..
Bruce.
homeinva
SUFFOLK,VA
might want to check and make sure the radio did not have other channels added
know that was a radio that they could add more channels
if it has a selector switch or dial switch
australia
Thanks for the quick reply homeinventa,,,
There does NOT appear any extra channels ,I don't see any mods or extra switch on the fron panels --all very original ..
Tried this morning ,same problem ,20 channels down out of the 40 channels ,all over the place..
will take the cover off and spray electroclean on the rotary switch , but I think it's more sinister than that..
Bummer, one problem after another -first was a crook rotator,then my 2 mtr wide band receive don't work ,now this.. oh and the meter lights and dead segments ..lol..
Bruce
homeinva
SUFFOLK,VA
did you receive on any of the channels if so you might have some finals gone
been a few yr since i have had mine on
australia
Thanks Homeinva,,,,, I can get ,receive and tx , on about half the 35 channels ,, some in blocks of 3 or more , others just a single channel .
So, we'll say 18 channels are OK ,, so thats OK .
Why this problem is happening ,dunno.. seems spread over the whole 35 channels..
Bravodownunder--VK4FBDU
John_S
Saratoga Springs, NY
Sometimes the guys adding extra channels would try to not add extra switches. They would use one of the accessory switches... like SWR or something similar. If you see additional wires that don't look factory and they run to the front panel, that's the explanation.
australia
Thanks John ,,
No, everything appears to be factory standard ... I have 2 washingtons and both are looking the same inside ..
I'll use some "electro-clean" on the rotary switch next time I have the case off ..
But does this channel selector then send a signal to a multi channel chip ? which could be sick ?.
Bruce.
John_S
Chances are then that it's probably the switch...yes, it works with the chip. Not sure if this may be a sealed type of rotary switch or not.... been a long time since I did anything under the hood of a CB... early '90s.
a possible crystal problem I have a galaxy that had that problem. but then again my galaxy had many bad solder joints I had to find also. You could try heating any crystals in it with a hair dryer thats how I found my problem. Just a thought
