Waterbury TRS ?
W1CRN
Liberty, SC
Ok before anyone jumps on me and says that you can’t legally do this. The FCC states as long as your are not cloning IDs, reproducing IDs and/or interfering, affailating with, or causeing harmful interference with that this is perfectly legal.
I am trying to program the trs into a Motorola radio with the hidden talkgroup/non affiliate scan method. I have done this multiple times on a Smartzone system but never a phase I system. So fast forward I get it programmed and it changes to an active talkgroup while scanning but there is no audio. I have verified that the speaker works by putting in a simplex channel and using a portable to test. So I set the offset the talkgroups and the system up right as I’m receiving a transmission but there is no audio at all
Someone might have a little insight to help out?
N1GTL
CT
Waterbury uses Johnson radios with a control channel that changes. I'm not sure if the Motorola you have can follow a Johnson system.
W1CRN
Liberty, SC
Yeah that’s what I’m thinking. I thought the FD uses APX a that’s why thought this would work
N1GTL
CT
Short of getting one of their model radios, you can put all 9 repeater channels in and just scan them. The whole city is on the system but from 5:00 pm until about 8:00 am, the police and fire are really the only active agencies. You'll just need to lock out the control channel manually as it changes.
APX7500X2
NY/CT
I listen to Waterbury with the hidden talkgroup/non affiliate scan method on an XTS2500 and APX6000 with no issues at all
cg
Connecticut
Not sure if it makes a difference with the commercial radios but the band plan for Waterbury is not the default.
chris
N1GTL
CT
Well, if APX7500X2 knows how to set it up, it would be nice to share. Isn't that what the forums are about? I am both out of range of Waterbury and have no interest in monitoring them. I don't know how so I cannot offer any further suggestions.
ansky
NJ
This is what I was going to suggest too. It's obviously not ideal, and you may miss conversations, but it's better than not hearing anything at all. Way back in the early 90's I used to monitor the Bristol TRS this way. This was before the PD went encrypted, and at the time they only had 3 active frequencies in use, so it was pretty easy to follow.
W1CRN
Liberty, SC
I’m using all the info from RR Database. So if it’s not genre that’s why it’s not working. Would you mind lending a hand?
