No reviews of the WellGOOD but I do have the Wellbrook for 0-30 Mhz and it's an excellent antenna for BCB or SWL... to use it to is maximum capability you need to be able to rotate the antenna to null out competing signals/noise, and maximize the desired signal... unless you can do that while sitting down with the antenna next to you then you will need a motorized antenna rotator setup, which I have. It's fine if you are locked in to one station for a while, but for band scanning it's a pain in the b&tt... most of the time I just use by 100ft random wire or 250' sky loop, both are on a two way antenna switch and I can use which one gives the best signal.
