Westfield, Ma. Area.....
cg
Connecticut
859.9375 114.8
858.2375 114.8
From Scannermaster 10th edition ... worth the price.
chris
pcfn360
Auburn,MA
Westfield,PD
114.8 is the PL tone. Depending on your scanner you should be able to input these tones called either PL CTCSS,DCS or DPL.
It's a sub audible tone that makes the user in this case westfield, the only agency you will hear on that freq if you have the PL tone programmed.
Hope this helps.
Ed
Slugworth
Westfield, MA.
Hope this helps.
Ed
Thank's...
I have the Pro95 scanner..
Does that mean they are useing a Trunked system?
cookiend15
Banned
Westfield, Mass
I would give www.cityfreq.com a try, also I would try the DATABASE on this website and go under Massachusetts and see what you can find there. I hope that this helps you out.
Chris
