DSDPlus What causes this happen on a trunk system.
bravo14
Polk County FL
This happen yesterday and 3 times 10 times ago. Was on local p25 and than this happens. What causes this throw a error?IMG_6359.jpeg
bravo14
Polk County FL
You probably do not have the DMR system in your DSDPlus.frequencies file, but others may be able to respond better.
I'll have the P25 trunk system running and all of the blue it will switch over to that saying it's dmr which it isn't.
What P25 site are you trying to hear, and what tower? Are you sure it is the closest tower, and no DMR system is close to you?
cg
Connecticut
That happens to me with a P25 trunk system that uses shared business channels. DSDPlus starts decoding present DMR traffic once the P25 traffic ends. It creates odd System ID and looks fine except does not work.
For me, the answer is to shut off all modes except P25 and then it is fine regardless of DMR traffic at the same time.
TheButcher
Add " -f1" to command line for DSDPlus to force P25 (Phase 1 in this case).
How good is the signal from your aerial ? You need an outdoor aerial ideally and to have gain set up right in FMP24.
