ka3jjz
Wiki Admin Emeritus
Yeah, as I commented earlier, his 1680, plus all the junk showing up on LW from the MW band (which is a common problem) is all indicative of an overload issue. I believe he has a Wellbrook loop, and if it's pointed directly in the path of the MW station, it's very likely to be the cause of his issues, which is why I suggested turning that loop away. It's almost like 'looking down the barrel of a blowtorch'...
In addition, adding a LW filter wouldn't hurt either. The R71A is a very old receiver, and I wouldn't doubt that some components have drifted out of spec over time.
I hadn't thought of an unintended radiator, but you're quite right, under the right conditions it might rectify a RF signal that was strong enough. The problem is that it could be more than 1 joint, bolt or connection that could be doing this, and narrowing this down is likely to be a bear. Too, if you live in an apartment or condo, you have little control over the exterior.
MIke
MIke
