What is this? XTL usb type C
K2NEC
5F6
Exactly what it says it is. A rear programming and speaker adapter. Looks super convenient but keep in mind its made by the seller and may not work as intended
nokones
Sun City West, AZ
Be very careful with homemade or most after-market accessories that are for programming Motorola radios, especially the XTS/XTL series radios. It won't take much of a glitch or some signal/data interruption or interference during a programming procedure to brick the radio. If it was not engineered or assembled by Motorola, I would think twice before using it.
jeepsandradios
East of the Mississippi
Appears it would work well to program as long as the radio is not setup to require ignition. I guess for guys who have it on their desk and program often it may be of calue. I just order the read USB setup for mine.
merlin
DN32su
My guess is just an adapter to USB-C. May be handy if your programming setup is USB-C only.
dickie757
Wired
Out of range
I can see your point, but it could technically give 12vdc by way of Power Delivery handshake. The latest tech is PD programmable...voltage resolution down to 0.02 volts.
Does this gadget have it? No clue, but pin 25 is populated.
marcotor
I ♥ÆS Ø
Sunny SoCal
Those pins being right out in the open like that gives me anxiety.
It's not like it will be bouncing around. I would wager this is a solution for a desk radio that has no need for ignition sense and Hammy/Monitor types given the 3.5mm speaker jack. Plug it in the back of the radio, and viola! - there are no pins sticking out.
