what mhz range is generally CB on? just curious :)
AuntBee09
WA
i originally thought it was in the upper 140s, but i figured out that's ham (i think, right?).
i'm consider getting a CB. if any of you have some advice, i'd love to hear it. thanx
kb5udf
Louisiana
CB Frequency Range
About 27 mhz. For example CB channel 19 is 27.185 mhz (AM). Since you ask for advice, any kind of range on CB really needs an outside antenna.
The 27mhz signals a CB uses suffer severe loss when the antenna is inside of a building or vehicle.
144-148mhz is the ham 2-meter band, the most widely used for ham repeaters.
Other CB like services in the us are:
MURS: 150-155 mhz (approx)
FRS/GMS: 460mhz range
49mhz = cheap walkie talkies, old cordless phones (frequently AM)
AuntBee09
WA
o wait, another question: i read the info link about CB radio and it says "Most of the general public has moved to FRS or GMRS" so if i'm looking to get a radio, should i get one of those kind?
R-32
Snohomish Co. Wa
I would get both.:)
I can talk a greater distance with my CB, but Im set up a little better with a Cobra 2000 Base station, and Antron 99 antenna.
zz0468
Banned
The answer depends on what you want to do with it.
1. If you want to talk to truckers on the highway, get a CB.
2. If you want to talk to family members at the amusement park or on a hike, get FRS.
3. If you want to use it to conduct business or have your wife give you the grocery order on your way home from work, get GMRS (FCC license required).
4. If you want to chit chat and/or work DX, get a ham license. Morse code no longer required.
5. If you want to do all of the above, get one of each.
EFjohnsonVHF
Banned
USA
I'm reading this having operated on every band I'm legally entitled to, And I have to say that the CB in my area gets kind of rowdy, So I find it the most fun, But like earlier mentioned, You need Power X Antenna, So FRS is nice when you want something simple, MURS is nice as well.
commstar
As I recall, what is now GMRS was at one time (years ago) referred to by the FCC as 'Class A Citizens Band' and 27 Mhz CB was 'Class C Citizens Band' ...... anyone else on this?
If you are reading something from the 80's or before then this might have some relevance.
Coolest thing I craziest/saw/heard on 27Mhz CB back in the day- a repeater using a gonset transmitter!
