What software does the TK-2180 use?
apx7000xe
GA/SC State Line
Just purchased a radio off eBay and I would like to know what software it uses so I don't buy the wrong version. Here's a pic of the back of the radio to show the model number.
Motorola HT1550•XLS | Motorola HT1250 | Motorola CP200XLS | Kenwood TK-790 | Motorola Minitor VI
skiingchamp257
Before you buy the software, I'd make sure you get the updated software (which I believe is version 1.6). Depending on what firmware is on the radio it can enable more functions such as MDC-1200.
KPG-89DN Version 1.61 is the latests, released back in November of 2012.
You'd need to be careful since some of the software/firmware versions can force narrow band on the 150 and higher frequencies. Below 150MHz, it'll still do wide, so not an issue for the amateurs. If you plan on using it on Marine VHF, etc. you'd either want to keep an older version, or spring for the W-license to allow wide band programming again.
Latest radio firmware version is 1.22.
Again, think carefully before updating the software/firmware.
KK6ZTE
California
That's not an issue on this radio.
89DN will enforce narrowband but that's only in software not in firmware. You can read the same radio again in 89D and make necessary changes.
V1.22 was the last firmware release, but significantly older than 89DN.
89D and 89DN both share v1.61 releases, the only difference being narrowband (and 89DN doesn't work with TFS)
Baker845
radio's aren't toys.
Oregon
I have two Tk-2180, both have updated firmware for MDC and i use 89D V1.61. This version does Narrow and wideband. Did the radio come with a housing case?
Seriously?
Yes. Looked like in the photo yours was missing the case.
You could order a new case from a Kenwood dealer. Part number for the K model is A02-3847-03
Recasing radios isn't uncommon. Since they'll take a beating in the real world, it's something that many shops will do.
Other options would be to buy a broken radio with a good case and swap, or look for an after market supplier. Other items you'll likely need:
Rubber keypad "Packing" for K model. G53-1598-01
Side button covers: K29-9302-23 and K29-9303-03
Knobs:
Volume K29-9304-03
Channel K29-9305-03
Like I said, an option might be to buy a broken radio and just swap the parts over.
