What type of crimp connector do I need for the 10 wire flat conductor between the radio and remote head?
JoshuaHufford
Jefferson City, Mo
I need to crimp a new end on the 10 wire flat conductor that connects between my radio and remote head in my car. What kind of connector is this so I can get some?
Thanks!
AFD103
Assuming you're referring to a remote head CDM, the connector is commonly referred to as an RJ50.
RJ-50 10 pin/10 conductor, as AFD said.
However, the outer two pins are for DTMF (If I recall correctly), and not needed if you are not using a DTMF mic. I use the standard mics with mine and use a standard RJ-45 "CAT5" cable between the RF deck and control head. Been working fine for about 10 years now.
JoshuaHufford
Jefferson City, Mo
That connector worked great, thank you.
I have also used a regular Cat-5 cable before and I do know they work, however this is in my car and I already ran the 10 wire flat conductor that came with the kit through the floorboard and headliner so I needed the correct connector for this cable.
