texscan0985
- Joined
- May 14, 2007
- Messages
- 5
what scanner will work on the new digital stuff?
Your going to get lots of different answers to this but after reading everything posted recently I would have to say the best at this point in time are the GRE PSR-500 and 600.
It will also depend on where in Tejas you are located (if your handle holds true). Most of San Antonio and Bexar County are EDACS Provoice which cannot be decoded by any scanner. If you want to know more on that, do a search. There are several threads and a couple of wiki articles on that topic.
I could be wrong but it' s ESK edacs & can be tracked with GRE PSR500 .. according 2 to Webmaster Lindsay?![]()
I will stand partially corrected on this. ESK EDACS and Provoice may be tracked, but the Provoice cannot be monitored nor can the digital portion of ESK (read that as audio that can be understood). So it is hit or miss. If the system is digital, then ESK cannot be monitored.
I may be wrong but the box on the 164 says it will do 700 mhz trunking i may be reading it wrong can some one clarify this for me
AlabamaRS said:I could be wrong but it' s ESK edacs & can be tracked with GRE PSR500 .. according 2 to Webmaster Lindsay?![]()
