Where to find KPG 46 Cable?
KN4HTC
I've got a TK 7160 and a TK 981 and the programming software for both radios.
Doing my research, it looks like both radios take a KPG 46 cable. Is there a good source for them that's not $100? That seems a bit high for a programming cable.
a417
The KPG-46 is a serial port programmer for those radios, and the magic behind it is a RS232 to TTL level converter chip that allows the radio to talk to the computer. I built mine on a breadboard and it cost about $11. It was a MAX232, 7 caps and a 78L05. Dirt simple level conversion. I only had to program the radio once (and could rebuild it again if needed) and it worked just fine. The $100+ I see around are ones that have a USB to SERIAL converter built in, and consequently some scumbag markup involved as well.
As the Antenna Farm has a good reputation around these parts, I'd start here and try theirs for $40 ish.
MTS2000des
5B2_BEE00 Czar
a417
Good to know @MTS2000des , I'm always leery of ebay cables as they are misrepresented in perpetuity (and I frequently use them for parts.) I recommended the AntennaFarm as their customer service has to be better than ebay sellers. I just went the ebay route for an ICOM programming cable, and was told that the reason it didn't work was because I didn't install the correct Prolific driver....
...for the serial port.
No refund, days of emails to be told all sales are final. As I "refused their customer service request to install their prolific driver" I ended up going to ebay for dispute.
Cracked it open to find the DE-9 pins shorted by a solder blob.
KN4HTC
You have got to be kidding me. Considering the fact that I have ordered multiple things from there, you would've thought I would have checked there. Ha ha ha. Thanks!
AK9R
Central Indiana
I usually go to Valley Enterprises for radio programming cables. They have models for most popular models and they have cables with FTDI RS-232 to USB chipsets. I feel safer buying from Valley than from an unknown eBay seller. $21.49.
Vern
Union County, GA
Look at KPG-46z on ebay by seller BlueMax49ers for $28. I use it on my Kenwood NX-3700 series. It surpasses my old TTL cables which took 4 minutes for a read/write and this one takes 28 seconds. Seller is a ham and I have several of his products.
Vern
a417
86942
...this is where it started, deteriorated over time.
KN4HTC
Wow. Yeah I'll stick with the Antenna Farm then.
My last conversation with them went like this:
Them: The NMO mount you ordered is actually out of stock but we've got this one that actually a little better we can substitute.
Me: OK. Thanks.
Them: We'll get it shipped out today!
a417
Yeah, that's not saying that all ebayers aren't scumbags...but this one was. @vagrant & @W9BU both posted a seller they have had personal experience with, so that's better than just some rando. YMMV.
