I am on a tight budget and had to save over a year to get my scanner but do plan on getting scanner coax some time in the future if I can. thanks again.
As was so well stated above, neither the scanner antenna port or the scanner antenna provide a perfect 50Ω impedance across their usable bands. There's zero need to replace your RG-6 if it's working to your satisfaction.
It's easy for us to quote all kinds of specifics about what you 'should' use, but the reality is that for many, this is just a hobby. Like yourself, not everyone has a large discretionary budget to throw at this sort of stuff. The RG-6 will work just fine and if you are happy with the coverage, there's no need to change it. It's unlikely that you'd be able to tell the difference between LMR-400 and the RG-6 you have. Yes, there is a slight improvement on paper, but your scanner and your ears may not be able to tell the difference.
Instead, take what money you have available for hobby activities and put it towards a good antenna. Also, make sure you -fully- waterproof all outdoor connections. Leaving your outdoor connections unprotected will result in water ingress, either from rain or condensation, and that will result in corrosion. That corrosion will really impact your listening.
