Yet Another Multicoupler Thread
Kiniutech
Past login as: questnz
Somwhere in the South Pacific
Hi, Dumb question. I am using Eletroline EDA 2400 splitter for 3 scanners + SDR's
Also, recently I acquired Nooelec Flamingo FM Filter. At the moment filter is connected to Air-Spy 2 SDR feed alone (after Splitter)
Question, can I move FM filter Before the splitter to filter all 3 feeds or buy additional filters for each scanner?
sonm10
Central MN Monitor
Sauk Centre, Minnesota
FM broadcast filter should come before the splitter
yellingsoftly
Been thinking through this and I haven't been able to get Stridsbergeng. to respond. Maybe just swamped but makes me nervous. Thinking I may just take a zhl-1010 preamp and then a ZCSC-8-13-S+ 8 port minicircuits splitter. I already have an noolec 20db lana wideband lna and fm notch filter right next to the antenna that seems to work really well so just a preamp to overcome the loss of the splitter and no more would probably be good to not increase noise. Any issues with this plan? I'll probably have 6 sdr's running off this.
prcguy
I would avoid cascading preamps and 20dB gain on the noolec for a single preamp is generally too much for a low performing amp. Using just the ZHL-1010 feeding an 8-way divider will give you basically unity gain at all ports. You could use a ZHL-2010 with 20dB gain and a 6dB attenuator on the output giving about 4dB gain per port which is about the most I would recommend.
yellingsoftly
Ok hmm, this is all hooked to a no gain radioshack discone mostly for airband stuff. The noolec makes a huge difference provided the notch filter is there (before the fm notch aweful) as I have 70ft or so run of lmr400 so without it I just hear so much less. Was just trying to split it off so I could record more airband frequencies at once for research plus some acars/vdml2 stuff. Didn't want to lose the gain I already had. Here's what the nooleec lana specsheet says.
+20dB of RF gain at 1000MHz
0.9dB noise figure at 1000MHz
prcguy
Those are just two parameters. What about 1dB compression (IP1) or third order intercept IP3? Those numbers on the ZHL amps are really good but the nooelec probably sucks. The nooelec preamp as about $35 and the MiniCircuits is $190, you get what you pay for.
And preamp gain is not a substitute for antenna gain, two different things with two different outcomes and too much preamp gain
is not so good.
Pape
Quebec
That is a lot of amplification. Did you try to pad the current setup and see if you really need all that much amplification ?
I also run a lana + flamingo on a dicone over 75' LMR 400 on an ZFSC-8-43+. I can pad the analog signal for 3 DB without lost in the 100~200 MHZ. The estimated db at that frequency is 10 DB without the -3 DB.
yellingsoftly
Thanks for sharing that is my setup exactly, I guess I'm still new to this and learning. I haven't tried padding the signal. What are you using to pad the signal and dumb question how do you know when to pad the signal vs not? I do also listen to mil air bands in the 300mhz as well if thats relevant.
Pape
Quebec
Currently I run without any padding.
Let say I did the permutation test, from: original, antenna coax and my main receiver to all the equipment, Ant -> filter -> lna -> coax -> bias-tee -> spliter -> receiver.
I found out that adding -3 DB to the line before the ZFSC-8-43+ did lower my signal but the voice quality remained virtually the same, at -6 I was earing degradation on the week signal and so on. Since the -3 db did not remove any negative (some small interference) I decided to keep it simple and remove it.
This is a portion of my spreadsheet to give you a idea
MHZ
100​
200​
300​
400​
Coax
0.95​
1.35​
1.65​
1.91​
Spliter
9.84​
9.93​
9.96​
10.06​
Patch
1​
1​
1​
1​
Lost
11.79​
12.28​
12.61​
12.97​
LANA
22​
22​
22​
22​
total
10.21​
9.72​
9.39​
9.03​
My personal advice is just add the ZFSC-8-43+ and if you find it to have a lost of quality than start looking at LNA.
yellingsoftly
MHZ
100​
200​
300​
400​
Coax
0.95​
1.35​
1.65​
1.91​
Spliter
9.84​
9.93​
9.96​
10.06​
Patch
1​
1​
1​
1​
Lost
11.79​
12.28​
12.61​
12.97​
LANA
22​
22​
22​
22​
total
10.21​
9.72​
9.39​
9.03​
Ok thanks appreciate the advice and the spreadsheet. That gives me some ideas.
Ubbe
Stockholm, Sweden
The Electroline devices are designed to handle huge signals from TV and Radio broadcasters, so it will not need any filters, as much as your receivers will, but to save money you put it on its input. That Flamingo are stated at max 0,9dB passband loss so that small amount are not noticeable.
/Ubbe
Pape
Quebec
Ok thanks, I'll keep that in mind. May try without and add as needed.
Depending on what you wish to do.
If your goal is to remove FM band for all connected device you put it before the amp. Also make the filter more effective as it does not need to fight the added DB from the amp on that band, if any. I did not look at the spec. If you have any LNA, I would say before the LNA also :)
If you want to maintain one port with all band at full than, you will need to put one per port you wish to filter the FM band out.
Kiniutech
Would inline Nooelec Flamingo FM Filter make much difference in vehicles installation?
NMO Mounts, Larsen and Laird Triband antennas, handheld scanner, no multi coupler, direct cable run 3-3.5 M
Listening mainly to 75.xxx, 485.xxx, Civ Air
any advice will be much appreciated
Ubbe
Stockholm, Sweden
When I use scanners mobile the antenna are at street level and are much more exposed to everything that emits RF at that level, gas pumps, vehicle electronics, practically everything that are electronic will have some high speed data clocks or oscillators/CPU's that emits RF noise. I haven't notice much of broadcast overload issues compared to all the RF hash that exists in nearfield.
/Ubbe
yellingsoftly
Do you hear fm stations out of band now? Also not sure by Civ air you mean airband? If yes fm filters can make a big difference since air and is so close to fm stations being in the 118-134 mhz range. Not sure how mobile antennas would affect it I only have a base station
