fmon said:
I do note that the tables are misplaced on the ALMR page also, thus cannot be imported with Web Import.
OK, now I understand what you're saying and why the Web Import doesn't work.
The only reason I could think of why is done this way is the same reason you mentioned. The current way allows everyone to do an import regardless of scanner brand and for those that need the Tables, they need to enter them manually. Otherwise, I can see how those tables could create problems with Uniden users during an import, especially since Uniden only allows 3 of them.
fmon said:
Except you didn't say the part about the Pro-96/2096 in your first answer.
I'm editing that to show it now!
EDIT: I guess I can't edit it after all, too late.
fmon said:
kikito,
I wasn't being critical, in fact, I salute your input to this and other forums. Your state planners have provided you with a great challenge in the ALMR system and you have provided considerable info on how it works by pioneering the Tables early in the life of the Pro-96. This type of info is invaluable to us normal scanner users.
No problem and thanks.
I did get a lot of help from many people in this community like wayne_h (trunked system knowledge), Mike Vanderveer (excellent Pro96Com software), Don Starr (GRE radios knowledge) and several others, so it was more of a group effort.
