whislter 1065 scanner at walmart
troymail
Silent Key
This radio is based on the original GRE PSR 600. The PSR500 (which I own) is the handlheld version of the same radio. These are great radios and the only limitations I know of are:
- no onboard library (manual programming and/or purchase separate software like Win500)
- does not do P25 Phase 2 (but does do Phase 1)
Having said that - these radios do provide a few other additional features that were not carried over into other radios.
The only other thing that comes to mind is that everyone has different outcomes with just about any radio that is on the market when it comes to "digital simulcast" issues. However, that's a consideration regardless of what radio you might buy.
$285 is a pretty good price....
Some references:
WS1065 - The RadioReference Wiki
https://www.whistlergroup.com/usa/product-catalog-us/radio-scanner/ws1065-scanner-radio.html
gewecke
Illinois
Its too bad my walmart doesn't carry scanners. :roll: I don't remember ever seeing one there. You're lucky! 73, n9zas
AA6IO
Cerritos, CA (LA County)
I have the WS-1065 here in Cerritos. It is an excellent scanner. Does P25 phase 1 LAPD sounds great on the scanner. Pretty good trunking of LA ICIS and OC CCCS. At that price, you should really consider it. I think you will be pleased. Software makes programming much easier. An excellent radio for So. Calif monitoring.
stingray327
San Francisco, California bay area
i looking to purchase a whistler scanner that walmart has on sale for 284.34 does anyone own one already give me some input on how you like it.and is it a systerm scanner are banks scanner like the older radioshack scanner where at one time. i know it does not receive phase 1 and 2 that ok.
Whistler Desktop Digital Trunking Scanner - Walmart.com
I just returned a Whistler 1095 Scanner. I didn't like the EZ programming or the scanner. Got lots of "errors" with lots of difficulty setting up program.
scma127
Fontana California
whislter 1065 scanner at walmart Reply to Thread
thank you for the input and i did not know it does phase 1 great to know that i look at the manual on it and it say not about monitoring phase 1.and i live in compton so it not digital but in close to lacity so i can list to lapd and lafd as well i would love to listen to orange county and i cam monitor icis and thankyou for you inp ut i guess if i purchase it i will use butel software arc500 thank you all especially about the monitoring of phase 1 did not even know that thank you
Fireboat03
Pepsima1 Duplicate Account
For the price the radio is a great deal. Looks like you live in the Compton area. I have one of those WS1065 radios and love it in the SOCAL area too.
Now with Compton part of LASO and moving over to LA-RICS I would think about buying a Phase II scanner since LA-RICS is Phase II.
DickH
I did the same a few months ago. EZ Scan is anything but easy. I bought a PRO-652 and used the ARC500 free trial to set it up. Not easy, but MUCH easier than EZ Scan. Digital Phase I works beautifully.
rwier
Phoenix, AZ
Just add something I don't think has been mentioned: The GRE 600 (a close cousin) has the best speaker of any of my scanners, and it is built like a tank. For ten years I left it outside in the carport to listen while doing "shop" stuff. At 3/4 volumn, I could hear it easily across the street at a neighbors.
gewecke
Illinois
. +1 on this. The best P25 audio too, for a scanner :). 73, n9zas
rwier
Phoenix, AZ
I'll bet all the other neighbors were thrilled !
Nearly all are day workers, so I have no daytime data. However, whenever I am out in the driveway after dark with my telescope/s, they congregate readily. With the scanner running quietly in the background, the comments range from "I didn't know you could do that." to "That's pretty interesting, can you turn it up a little?"
pilotman6012
Athens Alabama
There is no comparision between Whistler and GRE,doing some tests between original GRE and new Whistler 1065,same antenna and connectors for both, scanning the same band for the same amount of time.The Whistler failed on every level,Scanning aircraft band 118.05-136.00,Gre Found 45 Channels including all the local channels,while Whistler barely got 8 and most of them were high altitude channels and NO local channels.Unfortunately i am done with Whistler.Same thing on public safety search,GRE found 55 Channels while Whistler found 7.Absolutely worthless!!Anybody want a fairly new 1065 with all accessories and the box.
stingray327
Same thing here, I am done with Whistler. Customer rep never got back to me even though he kept assuring me he would.
Blackswan73
Central Indiana
I used a Pro 652 for a couple of months, then sold it to my daughter in law's mother. Worked great, and had great sound. This is the same radio as the 1065, and is made by Whistler. I also have a 668, and 1095. Very satisfied with Whistler products. Can't say the same for my 536 tho. I am very disappointed in my 536. I would sell it, but it is the only radio I have that will fit in , hence the only reason I keep it. If I remember correctly, the 1065/652/600/197, had an in dash option
