WS1010: Whistler 1010 and Los Angeles Sheriff
GrandpaFrank
Hello folks, I recently bought a Whistler 1010 for a nephew of mine who is only interested in the local Sheriff which is analog and Not LAPD which is P25.
I copied the frequencies and names and pasted them into the PSREdit 100 program and pushed the file list to the scanner. The problem is, the transmissions are all choppy, hit and miss, with alot of static, beeps and hisses. Is this normal? Did I do something wrong? Here is an example:
Frequency License Type Tone Alpha Tag Description Mode Tag
483.98750 WII799 RMCSQCVS-ALTD1Disp 1 - Crescenta Valley / Altadena [L-TAC 8] FMN Law Dispatch
and in the pc program, I have
CH Frequency DLY L/O. Sq Mode. Sq tone. Description
The Sq Mode I have set to CT/DC since I get slightly better results and there is no CSQ option, and the Sq Tone is set to SRCH
Am I doing something wrong?
gmclam
Fair Oaks, CA
Make sure you have PRIority off. This can be active on any channel and causes the radio to constantly interrupt what you're hearing to check on a channel with priority on.
GrandpaFrank
Thank You for the reply. I have pretty bad reception with the stock antenna, maybe it's just my area but I notice my TRX1 picks up much more constant and clearly.
