Who's Using LTR Passport?
KD4YGG
Was wondering who is using LTR Passport for public safety applications?
I know Montgomery County, Tennessee is.
Anybody, Anywhere Else?
KD4YGG
ETW
Georgia
PassPort
PassPort has few law enforcement users for the same reason as LTR, slow access, no priority and no emergency feature.
There is a system in TN as mentioned and a fed system in ID. Both are UHF.
SMR systems in quite a few states. All of them on UHF plus one on VHF.
Anyone know about 800 and 900. Only know of one on 900.
Joe
I have two systems with PassPort Backbone, but currently they are only running in standard LTR. One is UHF the other is 900. We are in the process of switching our police over to UHF from 900 as UHF works soooo much better.
KC5MAI
Midland, Texas
Been using Passport for around 5 years or so. Started with 800 LTR and Passport and now use UHF passport. LTR and conventional all in the same switch sharing some channels between all 3. 6 sites in the sytem all using the 3 protocols.
Mike
INDY72
Indianapolis, IN
Adams County MS E-911 Communications District: LTR Passport, for its multitasking capabilities, growth potential, and cheaper than most Motorola and EDACS systems.. and there are the crosssystem capabilities... LTR Standard can use Passport, and vice versus.
Buncombe County NC will be switching in the next few years to an LTR Passport system also.
The folks that diss Passport, and LTR in general really have no reason too with the growth and expansion capabilities of these systems. The only gripe I have is as a scanner user,.. LTR Passport is a pain to monitor. LOL
cg
Connecticut
Bloomfield and Windsor, CT have each installed Passport systems.
The Bloomfield system is in use by most town agencies (PD has a conventional backup).
The Windsor system has been shut off. There is not official word on why but the rumor is too many complaints about the time it took to affiliate with the system. I have heard that perhaps conventional LTR will go in but nothing for sure yet.
chris
radiogeorge
Collierville, TN-All Passport
Collierville, TN is "All" UHF passport, no standard LTR.
Police, Fire, & all city services all sharing same single site system.
Freqs on the RR data base page
sandcrash
LTR Passport in Telluride
LTR Passport on VHF is being used here in Telluride, CO. I have not quite figured out the best way to monitor yet. Any suggestions?
Thanks,
Sand
INDY72
Indianapolis, IN
Easy. Firstly put in all the repeaters with NO, I repeat NO delay,.. monitor it conventionally. If its not too busy, itll be easy to monitor. If its busy, itll be a PITA,..
If you put delays on the repeaters, it'll lock up on the data bursts every two seconds,.. and youll miss activity.
There is a trick to it using a scanner that has multiple priority chans. If the system has ten, or less freqs,.. you put them all in priority chans, and priority scan them, again with NO delays. This is as close to trunktracking as you can get on a Passport LTR so far. Eventually (in the next 5 years) youll see a Passport, and possibly, an Multinet LTR capable scanner.
KD4YGG
Plans are currently in the works to expand the current Montgomery County Public Safety LTR Passport system into a 7 county regional trunking system (North-Middle Tennessee Regional Public Safety System).
This plan, initiated by the regional homeland security council of Montgomery, Stewart, Houston, Humphrey, Cheatham, Dickson and Robertson Counties, is to allow interoperable communications within the 7 county region. There are plans for an Iden console (Nextel), APCO 25 integration, and patch ability into the Clarksville 800Mhz digital ProVoice system and Nashville 800Mhz digital APCO25 system.
All 7 counties have been updated in the database under "North-Middle Tennessee Regional Public Safety System".
