Why is 53 to 88 mhz blocked on scanners?
Well, most of that is TV channels. Wideband stuff that your scanner won't do anything with other than buzz at you. On the old analog TV systems, you could hear the analog wideband audio.
There is some LMR stuff in the 70MHz band, but there really isn't much to listen to there. It was used for some ~72MHz point to point links, sometimes used for linking repeater sites. Some older centralized clock systems used 70MHz.
Not really hiding anything there, just not much worth listening to for the average scanner listener. There are plenty of receivers that will cover that spectrum. Skipping it over on scanners may have been because getting good performance there with megawatt TV broadcast stations and FM broadcast stations was difficult on many receivers.
EWC_BDN
Back in analog TV days. The audio was the same as FM radio. So if you had a receiver that could be turned to the audio part of the signal you could hear the T.V audio.
If you're curious. Black and white NTSC TV broadcasting is pretty simple and there are good websites explaining it. It could be a fun thing to learn. I had to do a write up on it in college. The black and white part was easy to understand. When you throw colour in. It makes it more complex. especially since they couldn't change the Black and white part at all. Both colour and black and white listened to the same transmission and decoded them both.
prcguy
There is an amount of military traffic in the 53-88MHz range and in So Cal there are several common channels at 65MHz that I believe are Air National Guard out of Los Alamitos. I once encountered some National Guard guys in HUMVEEs out in the boonies near Frazier Park, CA and I happened to have a PRC-70 military man pack radio with me. I held up my radio to them and asked what frequency they were on and one guy flashed his hand with five fingers four times which I took as 55.55MHz. I dialed up my radio to that frequency and there they were. We had a quick hello and off they went.
nd5y
Wichita Falls, TX
75 Mhz is used for RC model for hobby use.......
There are also 72 MHz RC channels.
I don't think those are used much any more. I think almost everything except cheap toys (27 & 49 MHz) uses 2.4 and 5 GHz.
The rest of the frequency use in the 72-76 MHz band can be found at
Federal Register :: Request Access
Public safety and industria/business pool use
Aviation use
wtp
Port Charlotte FL
50 to 54 is ham
54 to 60 is TV ch 2
60 to 66 is TV ch 3
66 to 72 is TV ch 4
72 to 76 is mid VHF (not used much)
76 to 82 is TV ch 5
82 to 88 is TV ch 6
88 to 108 is FM radio
108 to 118 is air navigation (usually no voice)
118 to 137 air band
137 to 144 military air and land (AM air) (FM land)
144 to 148 ham
148 to 150.8 military air and land (as above)
prcguy
50 to 54 is ham
54 to 60 is TV ch 2
60 to 66 is TV ch 3
66 to 72 is TV ch 4
76 to 82 is TV ch 5
82 to 88 is TV ch 6
118 to 137 air band
144 to 148 ham
Most VHF TV stations across the US have been shut down and part of the VHF TV frequency range is supposed to auctioned off at some point.
spacellamaman
It seems on all scanners, it mainly skips over that band. Does anyone know why this is?
Why it is blocked on some i do not know, why it is not included I imagine is due to lack of interest due to a lack of knowledge that that range is used -heavily- by the military. I have tried at every occasion to pop the bubble of those who say there is nothing there, but unless you are someone who is actively tracking that spectrum, there is little reason to believe anything is going on there.
See:
I attached my compendium file here and see pages 20-23 for evidence.
There are a few scanners that cover the range BR330T, BCT15X, and BCD436HP being the ones I have used to pretty good effect. If I could figure out how to rig a scanner with a signal stalker/spectrum sweeper to cover that range I would be a happy little fellow. running a custom range search 54-76mhz at 25mhz steps is pretty quick though. I have yet to find anything higher than 76mhz and from my reading it appears that many of the old school non SDR radios topped out there and it makes me think there is infrequent use of anything between 76-88. But I still scan it when there is activity nearby.
  • NC MILCOM synopsis-AJ FREQS (2).pdf
wtp
Port Charlotte FL
people bought scanners to mainly listen to the police.
so that started the 30 to 50, 144 to 174 and 450 to 512.
sure, adding the 50 to 54 ham part would have been nice.
but less range would mean a cheaper price.
KevinC
Encryption
I'm everywhere Focker!
Ubbe
Stockholm, Sweden
The E model are just a modified firmware that anyone can load in their US TRX scanner but it doesn't include signal sweeper in the 68-88 range. The hardware band filters are still the US ones and above 68MHz it gradually loose sensitivity until almost completely dead at 75MHz, where it switches to the 108-137 filter and gradually improve some. But at best the range for normal scan are a couple of kilometers if not monitoring just at the border of 68MHz.
/Ubbe
spacellamaman
I take it from your response that will be a simple matter to order it from the first vendor listed on the Whistler page? As simple ordering it from the UK as ordering it stateside?
spacellamaman
/Ubbe
Thank you, that was a much more useful bit of info.
krokus
Southeastern Michigan
You could check for older scanners, too. Some had at least some of those freqs available in the variant made for other parts of thr world. My Pro-39 would tune the Australian low band public safety freqs, by moving a diode. I never tried to see if it was an outright switch, or just enabled a mode. (I would have had to move the diode from the North American slot. IIRC, I could not use the diode I pulled for restoring the old analog cellphone freqs.)
