K4APR
I just completed a build project tonight of a wideband (0-1000MHz) four port multicoupler. The unit consists of a Mini Circuits ZFL1000 +20dB pre-amp and Mini Circuits ZFSC-4 four port splitter. The case is an extruded aluminum case by Hammond, with a removable top plate (makes installing everything MUCH easier). The front and rear plates were milled on my in-house CNC machine. I used N Female to SMA female chasis mount connectors for both the input and output ports. I decided to put a small +15VDC switching supply inside of the unit, so I added a standard equipment power cable socket with built-in noise filtering.
I plan to do some more bench testing with an RF signal source and spectrum analyzer. In the meantime, here are some pictures of the build:
