[FONT=lucida sans typewriter, lucida console, courier]850
ACUS02 KWNS 281740
SWODY2
SPC AC 281739
DAY 2 CONVECTIVE OUTLOOK
NWS STORM PREDICTION CENTER NORMAN OK
1139 AM CST WED FEB 28 2007
VALID 011200Z - 021200Z
...THERE IS A MDT RISK OF SVR TSTMS PORTIONS
LA...AR...MO...IL...SWRN INDIANA...WRN KY...WRN/MID
TN...MS...AL...GA...SC...
...THERE IS A SLGT RISK OF SVR TSTMS ELSEWHERE FROM MID MS VALLEY TO
CENTRAL GULF COAST TO SRN ATLANTIC COAST...
OUTBREAK OF SVR TSTMS -- INCLUDING CONDITIONAL POTENTIAL FOR
STRONG-VIOLENT TORNADOES -- WILL AFFECT PORTIONS E-CENTRAL/SERN
CONUS. UNCERTAINTIES REGARDING INSTABILITY AND CONVECTIVE MODE
REMAIN ATTM...PRECLUDING HIGH PROBABILITIES THIS SOON. HOWEVER...AN
UPGRADE OF SOME PORTION OF CATEGORICAL MDT RISK AREA IS POSSIBLE IN
FUTURE OUTLOOKS VALID FOR THIS PERIOD.
..SYNOPSIS
IN MID/UPPER LEVELS...HEIGHTS ARE FCST TO FALL ACROSS MOST OF
CENTRAL CONUS...WITH EWD ADVANCEMENT OF TROUGHING NOW AMPLIFYING
FROM NRN ROCKIES SWD ACROSS WRN GREAT BASIN AND SRN CA. PRIMARY
SHORTWAVE TROUGH -- NOW EVIDENT IN MOISTURE CHANNEL IMAGERY OVER SRN
NV...SERN CA AND EXTREME WRN AZ -- IS FCST TO EVOLVE INTO CLOSED
MIDLEVEL LOW EARLY IN PERIOD INVOF NERN KS/NWRN MO...THEN MOVE NEWD
OVER WI AS OCCLUDING DEEP-LAYER CYCLONE BY 2/12Z. ASSOCIATED SFC
LOW WILL STRENGTHEN AND LIFT NEWD ACROSS MO/IA EARLY IN
PERIOD...BECOMING VERTICALLY STACKED WITH UPPER LOW BY END OF
PERIOD. ASSOCIATED COLD FRONT WILL CATCH FOREGOING DRYLINE EARLY IN
PERIOD...THEN COMBINED BOUNDARY WILL SWEEP EWD OVER OH/TN VALLEY
REGIONS AND GULF COAST STATES.
SFC/925/850 MB ANALYSES AND VIS IMAGERY INDICATES ROBUST LOW LEVEL
MOISTURE FROM CENTRAL GULF SWD...BOUNDED ON N SIDE BY BAND OF LOW
CLOUDS EVIDENT IN VIS IMAGERY FROM S FL WNWWD TO ABOUT 120 NM S OF
CENTRAL/WRN COAST OF LA. ASSOCIATED MARINE/WARM FRONT IS FCST TO
MOVE INLAND LATE DAY-1 PERIOD THEM BECOME INCREASINGLY DIFFUSE AS
INTENSE LOW LEVEL THETAE ADVECTION REGIME SHIFTS NWD THROUGH
THIS AIR MASS...PARTLY SAMPLED BY 28/12Z RAOBS FROM MONTERREY
MEX...BRO...CRP...MERIDA MEX...AND EYW...APPEARS CHARACTERIZED BY
BOUNDARY LAYER THAT BECOMES MORE SHALLOW WWD AND SWD AND DEEPEST
INVOF MARINE FRONT.
..AR/MO/IL...LOWER OH VALLEY REGION
PRIOR-OVERNIGHT SVR POTENTIAL DESCRIBED IN DAY-1 OUTLOOK IS EXPECTED
TO CONTINUE UNABATED THROUGH EARLY DAY-2 PERIOD...WITH DAMAGING WIND
AND TORNADOES BEING MAIN CONCERNS. ONE OR MORE LINES OF SVR TSTMS
ARE EXPECTED TO SWEEP NEWD ACROSS OZARKS AND ADJACENT PORTIONS
MO/AR...THEN INTO WRN/SRN IL THROUGH MIDDAY. DEEP-LAYER VERTICAL
SHEAR PROFILES ARE STRONGLY FAVORABLE FOR BOWS AND SUPERCELLS.
BUOYANCY WILL BE MRGL...WITH MLCAPES GENERALLY UNDER 500
J/KG...HOWEVER MODIFIED FCST SOUNDINGS SUGGEST SFC-BASED INFLOW IS
POSSIBLE AS FAR N AS PORTIONS IL/INDIANA. FAST STORM MOTIONS
EXCEEDING 45 KT ARE LIKELY...WHICH WOULD ENHANCE THREAT OF
LONG-TRACK TORNADOES FOR ANY RELATIVELY DISCRETE/SUSTAINED
SUPERCELLS THAT CAN DEVELOP IN THIS ENVIRONMENT.
..MID SOUTH...MS/AL
MAXIMIZED SFC HEATING WILL COINCIDE WITH OPTIMAL VERTICAL SHEAR AND
INCREASING LOW LEVEL MOISTURE TO MAXIMIZE RISK FOR SVR
HAIL...WIND...AND IN PARTICULAR...SIGNIFICANT TORNADOES. ALTHOUGH
MIDLEVEL LAPSE RATES MAY REMAIN AOB 7 DEG C/KM...SFC DEW POINTS
SHOULD INCREASE INTO 60S F ALONG AND S OF MARINE FRONT. THIS WILL
SUPPORT POCKETS OF MLCAPES 500-1000 J/KG...WHERE BREAKS IN CLOUD
COVER OCCUR BEHIND EARLY-PERIOD PRECIP ASSOCIATED WITH STRONG WAA
REGIME. THIS WILL BE SUITABLE FOR TORNADIC SUPERCELLS AND BOWING
LINE SEGMENTS IN ENVIRONMENT CHARACTERIZED BY LARGE LOW LEVEL
HODOGRAPHS -- 0-1 KM SRH AOA 300 J/KG -- AND 0-6 KM SHEAR EXCEEDING
60 KT. A FEW LONG-LIVED AND LONG-TRACK SUPERCELLS ARE POSSIBLE
GIVEN STRENGTH OF DEEP-LAYER KINEMATIC PROFILES AND RAPID NEWD
SPREAD OF FAVORABLE INFLOW-LAYER MOISTURE.
..CAROLINAS/GA...SRN PIEDMONT AND COASTAL PLAIN
FAVORABLE ENVIRONMENT FOR SVR OUTBREAK IS EXPECTED TO SHIFT/EXTEND
EWD FROM MS/AL INTO THIS REGION DURING EVENING AND OVERNIGHT HOURS.
RAPID BOUNDARY LAYER MOISTURE RECOVERY IS FCST DURING DAY AND
THROUGHOUT EVENING...FROM SW-NE...LEADING TO SFC DEW POINTS UPPER
50S TO MID 60S AS FAR NE AS ERN NC. SWLY LLJ OFF GULF IS PROGGED TO
INCREASE TO 55-70 KT RANGE BY 2/06Z AHEAD OF COLD FRONT. MOIST
ADVECTION WILL OFFSET DIABATIC NOCTURNAL COOLING...RENDERING INFLOW
LAYER SFC BASED OR VERY NEARLY SO. AS INCREASINGLY FAVORABLE
BOUNDARY LAYER THETAE SPREADS UNDERNEATH STRENGTHENING DEEP-LAYER
WIND FIELDS...ENVIRONMENT WILL BECOME FAVORABLE FOR SUPERCELLS AND
BOWS...WITH ATTENDANT RISKS FOR TORNADOES AND DAMAGING WIND.
..FL PENINSULA...AFTERNOON
TSTMS MAY DEVELOP OVER PORTIONS FL PENINSULA -- PRIMARILY DURING
AFTERNOON INVOF SEABREEZE BOUNDARIES...WHEN DIURNAL HEATING
MINIMIZES CINH. SRN PERIPHERY OF STRONGEST MID-UPPER WINDS SHOULD
EXTEND OVER PORTIONS CENTRAL/NRN FL...WITH SLY WINDS AT SFC
ENHANCING DEEP-LAYER SHEAR AND SUPPORTING POTENTIAL FOR A FEW
SUPERCELLS. 0-6 KM SHEAR AOA 50 KT MAY EXTEND AS FAR S AS LAKE
OKEECHOBEE AREA BY 1/21Z. INSOLATION AND SFC DEW POINTS UPPER 60S
TO LOW 70S SHOULD OFFSET MODEST LAPSE RATES ALOFT TO LEAD TO MLCAPES
500-1000 J/KG.
..EDWARDS.. 02/28/2007
73's
Ron
[/FONT]
ACUS02 KWNS 281740
SWODY2
SPC AC 281739
..SYNOPSIS
INVOF MARINE FRONT.
..MID SOUTH...MS/AL
500-1000 J/KG.
73's
Ron
[/FONT]
