- Joined
- Dec 19, 2002
- Messages
- 2,147
I live in a dense WiFi signal area and I need to remove as much RF noise from my surrounding. The biggest is WiFi, followed by cellular.
Before the proliferation of WiFi, I used to be able to pick up a repeater some 30 miles away. Now it barely make it past the noise floor.
So I need dedicated notch filters to really drown out the RF noise from WiFi, LTE, BC FM and shortwave. I have found notch filters for all the others, but I'm having a hard time finding anything for WiFi.
RF interference has to be quite strong to de-sense your receiver and near in frequency--you are considering too far away and really not that powerful. If you have already blocked BC FM, your problem is might be buildings that have gone up between the repeater and you (in my case, I have seen similar happen several times when buildings were built between) . An one has to also consider if a nearby TV station making the move to UHF from low VHF might be an issue. I am sure WiFi did not cause your problem.
