Wiki article damaged
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It's pretty simple to undo this. See the HISTORY link on the far lett when looking at the article? Click on that, then select the most recent time period that you believe to be correct. Click on Compare; you will then be presented with 2 versions; edit the version you wish, then at the bottom of the article, hit SAVE.
No need for any mod intervention here..Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Nope anyone can do this. The restriction of an admin only applies to deleting articles - makes it somewhat harder for a spammer - which we've had a few - to come in and do real damage
Mike
N4GIX
Hot Springs, AR
Ah, this works:
Medevac (TX) - The RadioReference Wiki
Instead of the parenthesis, it is using %28 and %29
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Unfortunately this is a long standing issue with the rightmost paren that has never been addressed. Very annoying...Mike
nd5y
Wichita Falls, TX
I forgot about the ) problem when I made the original post. I fixed the wiki article in question so no need to continue this thread.
