Will my antenna work?
78k10
Hickory NC
Hello gents. I picked up a like new RadioShack 19-1210 business band radio over the weekend. Planning to use it on MURS, I’m in the process of figuring out the programming process now. I have an antenna that came with a recent scanner purchase that I’d like to use, but I need help identifying it. I can make out maxrad on the base, but no model number. Under the antenna base, I see DC 207 and a couple other marks that I can’t make out. Does anyone have any idea what band this antenna is for, and if it can be tuned to the MURS band? It is an NMO mount, black loading coil, about 2.5” tall with a chrome band around the bottom. The whip itself is about 23”, and it has a spring. I would upload some pics, but the website keeps saying they are too big even though I’ve been doing the same way as I always have.
Additionally, does anyone know of a hardwire power cord for this radio? It came with a cigarette lighter plug, but I want to run straight to the battery. Thank you for any information.
The whip length sounds like a VHF 1/4 wave. The only way to know for sure what it's tuned for would be to use an antenna analyzer. But for the cost of even a cheap antenna analyzer or SWR meter, you can just buy several new VHF 1/4 wave antennas and not have any doubts.
That's not a Maxrad part number that I recognize, so I can't confirm that.
Just cut the cigarette lighter plug off and terminate the ends with what you need. No one should be using cigarette lighter sockets/plugs for radios.
78k10
Hickory NC
Thank you sir. I wish I could get some pictures to work, I’d like to know what I have regardless, so I know what it can and can’t do. I may just end up buying a new antenna, but if I can us what I have, I will. Do you know of a cowl NMO mount for a 2009 Nissan Titan? I’ve searched but haven’t been able to find anything that will work.
Just buy the new antenna and enjoy it. You'd spend more on an antenna analyzer or SWR meter.
78k10
Hickory NC
Many thanks to you sir. I figured if anyone had the answers, it would be you.
78k10
Hickory NC
I really wish I could find somebody stateside with these brackets. Freewaycom won’t ship to me, and Albertaradiosupply will ship but it nearly doubles the cost lol.
cpfinlay
Philadelphia, PA
Sounds similar to a BMAXSCAN1000 which is a receive-only (scanner) antenna covering VHF/UHF/800mhz. I have one of those myself and it works well. Here's one on eBay for reference: MAXRAD, BMAXSCAN1000, BMAX SCANN 1000 Antenna | eBay
78k10
Hickory NC
Mine looks quite a bit different. I was able to find one similar to it, although mine definitely has maxrad printed on the base. I found one similar on the internet, it’s the one second from right. Mine looks identical to that one . So maybe mine is a vhf lo antenna.IMG_6888.png
K6GBW
Montebello, CA
You can try the antenna farm. They might have something that will work. You can also do a lip mount on the back side of the hood. That gets done on jeeps a lot.
Mine looks quite a bit different. I was able to find one similar to it, although mine definitely has maxrad printed on the base. I found one similar on the internet, it’s the one second from right. Mine looks identical to that one . So maybe mine is a vhf lo antenna.View attachment 177529
Yeah, except those are low band antennas, and while the picture shows a short whip length, in reality, they are about 4-5 feet long. If your's has a 23" long whip, someone has either hacked it, or it's either a VHF 1/4 wave, or a UHF 1/2 wave.
78k10
Hickory NC
I know, but I was trying to find something that looked like what I have. Hoping that someone sees that and the model number and says oh yea that’s so and so. Mine came from a volunteer fire fighter so it may very well be some hodgepodge abomination.
prcguy
78k10
Hickory NC
They have one for the frontier and the rouge of all things, but nothing titan specific. I have a lip mount that came with the antenna, I may try that. It needs a new connector on the end of the coax though.
I’m considering just biting the bullet and punching the hole in the roof.
