Will Weather Affect What I Can Hear?
MikeThompson
Near Toronto, Ontario, Canada
Maybe a stupid question, but does my local weather affect what I can hear on shortwave?
I'm inclined to think if there is a massive thunderstorm in my area, the clouds and lightning will drown out many signals. But I'm also inclined to believe that if a radio signal travels through solid objects, clouds shouldn't be an issue.
Just something I thought of this morning. Do you guys find your reception changes because of the weather?
ecps92
Taxachusetts
Short answer is YES - but Time of Day [Local] and at your Target also come into play
Long answer is, there are many articles out there on that
I would google the phrase "how does the weather impact shortwave frequencies"
and spend sometime digesting the many articles - Enjoy the hobby
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yes, terrestrial weather can play a role as ypu've already said. Thunderstorms (and sometimes snowstorms, too) can carry a huge electrical charge that will increase the noise level and make things difficult.
In fact the seasons play a big role here - during the summer months the ionosphere gets more heavily ionized, thus making lower HF frequency reception more difficult. That and the increase in sunlight means the higher HF bands stay open longer.
And finally solar weather plays a big role too....Mike
jaspence
Michigan
There are internet sites that give you propagation reports for the different frequencies. There is a learning curve, and some are easier than others. Propagation is an example.
WA8ZTZ
S.E. MI
You mentioned "local weather".
So, the answer is "yes". And you gave the reason... thunderstorms.
The clouds themselves are not so much the issue, it's the lightning which causes the static crashes
heard on the radio. In fact, the affect can be more than local as the static from storms a hundred or more
miles away can sometimes be heard. The static is more pronounced on lower frequencies than higher and on
AM more so than FM.
Token
You have had some great answers so far. It can be argued that some of them are wrong, and some of them are right, but in general any errors are errors of omission. In crafting short responses the responders did not, really cannot without writing a book, cover all of the variables involved.
I am going to change the answer a bit by saying that local weather does not affect the shortwave signal itself. By local weather I am not including diurnal, seasonal, or solar cycle changes. Hear me out.
Local weather, rain, snow, fog, heavy clouds, lightning, etc, does not significantly impact the propagation of the signal from wherever in the World it is to you. It does not, in any significant way, decrease the signal level at your location. Sure, it can be argued that such local phenomena does change path loss or attenuation for the last few percent of the path, but realistically you are talking hundredths or tenths of a dB difference, not significant. Outside of a lab type environment you realistically can't tell such differences.
What local weather can do is change the local noise issue.
Static crashes from lightning. Rain static in an antenna, static caused by high winds and blowing sands, those kind of things. So local weather can raise the local noise floor and make it harder to hear the same signal, even if the same signal is not reduced in strength at your location.
But sometimes it (local weather) can also work in your favor. Here locally (the High Desert of California) we seldom get rain. Many times grounds are less than optimal, and dust builds up on power line insulators and antenna isolators. A hard rain, heavy snow, or a dense fog can come in and actually improve the noise floor by cleaning those insulators and improving grounds. During and immediately after a rain it is not uncommon for my average HF noise floor to be several dB lower, without reducing signals, than is my "norm". Outside of lightning crashes (short duration events that may be able to be filtered out, under some conditions) storms often make things better for me.
I think the take away here is that local weather does not affect the shortwave signal itself, they do not reduce the level of that signal by any important amount, but might change your local noise conditions, making it potentially harder, or easier, to hear. Most people only see the negative side of this.
T!
air-scan
Lightning is a noise source. Also high solar wind with high proton density on the Earth's magnetosheath can be bothersome in a CHHS (Coronal Hole High Stream) event. It's not a big problem during solar cycle rise time (just now beginning for SC25). They become more of an issue after the flip of the polar magnetic fields when coronal holes migrate poleward and are bigger. Solar maximum. The noise floor will rise very high in a M or X class flare event. That's prime time if you like whistlers, growlers, etc on VLF around 15khz.
dlwtrunked
...Also high solar wind with high proton density on the Earth's magnetosheath can be bothersome in a CHHS (Coronal Hole High Stream) event. It's not a big problem during solar cycle rise time (just now beginning for SC25). They become more of an issue after the flip of the polar magnetic fields when coronal holes migrate poleward and are bigger. Solar maximum. The noise floor will rise very high in a M or X class flare event. That's prime time if you like whistlers, growlers, etc on VLF around 15khz.
But that is not "weather". It may be called "space weather" at times but it is not weather.
air-scan
